Eye-Fi Wireless SD card: Propeller Hackable?
http://www.eye.fi/how-it-works/basics
Propeller Hackable? I could think of some pretty cool uses for Wifi connectivity via existing SD.
OBC
OBC
I ran across the documentation for my Eye-Fi card last night and started thinking along similar lines. Mine might be a (significantly) older version, I don't remember having the USB/SD adapter they show. I'll need to dig around for it and see.
Certainly could do some data logging to a PC. I'm not sure if it can talk from the PC back to the Eye-Fi except maybe for file deletion.
If I can find all the parts to mine, I'll be happy to send them down to Orrville for a loan. You will probably get around to hacking with it MUCH sooner (and more capably) than I will!!
BUT a SDIO WiFI form amazon may work as it is just a SDIO device not a SD storage card that can leak data to a WiFi chip .
I asked the guys at Eye-fi that very question a few years ago when there product first entered the market. They had no interest at the time. I hope it is a different story now.
http://www.amazon.com/Generation-Spectec-802-11b-Smartphones-Laptops/dp/B000BYR972/ref=sr_1_13?s=electronics&ie=UTF8&qid=1317178876&sr=1-13
http://www.amazon.com/Spectec-SDW-821-Network-adapter-802-11b/dp/B000RLBDIA/ref=pd_cp_e_1
If you now how to set it up ...... it may need only a few commands . Who knows .
The advantage of the Eye-Fi card is that it is a normal SD memory card and the WiFi is transparent to the target. So we're not trying to use the card for a general-purpose WiFi connection as there are much better ways of doing that plus it would load up the Prop's resources. However it's a great way to retrofit SD card products to make them accessible over WiFi (assuming we can).
Thanks for the links though.
have its on board Prop handle the heavy lifting ..
now its just a SD slot some GPIOs and a most of al software .
I recon that if a old Win CE device can boot that card then I am shure iur prop can ..
peter
