Speed Controller
Does someone know if you can use a digital potentiometer # AD5220 in place of the 100K potentiometer of a Speed Controller?
http://www.electronickits.com/kit/complete/motor/k166.pdf or if there's a different way of connecting it.
Thanks, Carl
Thanks, Carl
R1, P1, and R2 form a divider - the input to the buffer (x1) amp, IC1:A - ranging from approx. 1/2 of supply voltage to nearly 0V.
There are 3 versions of the AD5220, Parallax sells the 10KΩ version.
Your "Kit166V2" can run from as much as 32V (they claim.) So, the voltage you intend to run will have a lot to do with how appropriate any mod with an AD5220 might be.
"Piece of pie. Easy as cake." Russian astronaut, 2010
and a 2-Axis Joystick
Here's a link to some Electronic Speed Controllers (ESCs). You want to make sure you get one that matches your motors needs.
Duane
