Cluso's FT232 USB-TTL module - add a cheap PropPlug+ and 5V USB power to your project
Cluso99
Here is one of my new tiny pcbs. It is a PropPlug with a difference...
These pcbs are smt and purple with gold finish. The FTDI chip has fine pitch legs and the miniUSB also has fine legs. However, I found a fine tip soldering iron, fine solder, and a flux pen works fine.
I only had 9 pcbs made to try this out, so I have 8 available. Obviously this is not a profit enterprise, just a service to the forum. More pcbs take 3-4 weeks.
Bare PCBs US$1.50ea
PCB with set of parts (except FT232RL & miniUSB) US$2.80ea
Assembled and tested US$11.00 (please email me as I will need to schedult them to lack of time)
Unregistered Airmail Postage US$3.00 for pcb(s) only, US$4.00 for parts/assembled boards (from Australia)
My new website (still under construction) www.clusos.com/home
- Tiny pcb 0.6"x0.75" (15x18.5mm)
- FTDI FT232RL USB smt IC
- USB via miniUSB connector (cable easily obtained)
- Extended 6 pin PropPlug connector
- Center 4 pins PropPlug standard
- Top pin 5V linkable (above GND)
- Bottom pin unused (can link to RTS or CTS)
- Can Optionally provide 5V from the USB connection (PC)
- On a 3 pin header (use 5V & GND)
- On extended PropPlug connector by link/shunt on 3 pin header (link 5sw to 5V)
- Pins TXD, DTR, RTS, RXD & CTS brought out on small pad/holes
- Can be used with other microcontrollers
- A single LED fed by both the TxLed and RxLed pins so it flashes with data in either direction
Bare PCBs US$1.50ea
Nice work
It fits nicely with both my CpuBlade (1"x1" prop pcb) and BaseBoard1 (1.67"x1.76" prop pcb).
Should anyone require them soldered please let me know so I can schedule them and order the FTDI chips.
Good stuff, and I know you wouldn't mind me showing you my version that I use. It is designed to be compatible to the PropPlug on the bottom 4 pins and the top 4 pins have +5V from the USB and I2C as well as one reserved for application specific use. The I2C allows me direct access to the EEPROM for instance or I can just use the header on the target board as a convenient expansion header.
Same as you mate I used a micro USB connector plus I have a swag of low-profile pin headers so especially if I mount the USB interface upside down on a pcb then it sits very flat to the pcb.
Here's one of them plus how it can be permanently mounted onto a target board.
S
I am interested... do you get I2C by bit-banging on the PC to the CBus pins? I have seen they can program the ATtiny that way (by bit-banging Txd, DTR & RTS and using Rxd as the return) so I was thinking to program my first ATTiny that way and then get the prop to do it.
BTW I am in Bris on Tues but as usual time critical again. If I get a chance I will call you.
I noticed later that you were using a mini rather than a micro. I've found that the micro USB connectors are a lot more rugged would you believe and that's just what the specs say too. I'm getting my micro USB cables for a buck apiece.
The I2C pins are connected to the FT232 CBus pins and this "allows" access from the PC although I have never bothered to test it. The I2C is mainly for expansion or simply that direct access that I mentioned earlier as I can reprogram the boards out in the field or in production using a simple little stand-alone dongle to hold the Prop in reset while it loads up the EEPROM.
I know the ATTInys are cheap and small but so are my Silabs parts (DFN10 upwards) and I can program them directly from the Prop anytime
Do you want to catch-up on Tuesday? We can meet up, I've got some modules for you that you might like to play with.
I will be in central Bris and hope to be free before midday. ATM I think I may fly this time instead of driving so will not have wheels but can jump a train as long as I know where to go. Will be staying at Milton with a friend.
So, what I do with all my microUSB cables is to file off those little hooks. It takes just a few seconds and it limits the problem to hit only those phones which are more or less faulty from the start. In Europe all new phones are supposed to use microUSB for charging, so they're everywhere now.
-Tor
