Pins for C3 expansion header?
Anybody find pins that work well with the C3 expansion header?
I plugged one of my memory modules using what I consider regular header pins and it's very loose.
It's not making good contact. Also, jumper wires I put in the C3's expansion header are loose too...
Maybe you're supposed to use extra thick header pins there?
(Maybe I should try to find a part number for the female header and see what is supposed to mate with it...)
http://www.rapidonline.com/Cables-Connectors/Double-row-PCB-header-plug-2-54mm-pitch-28945
The Quickstart boards I have use what looks like a similar connector and a 0.64 mm square header fits that OK.
It's all too easy to spring a receptacle's leaves by forcing a too-thick wire or pin into it. Are all the receptacle holes that way, or just some of them?
It doesn't work unless I push on the board, putting some torque on it to make better contact.
I'll try cleaning my pins and see if that helps...
