Pins for C3 expansion header? — Parallax Forums
RaymanRayman Posts: 16,276
edited 2011-09-21 10:48 in Propeller 1
Anybody find pins that work well with the C3 expansion header?
I plugged one of my memory modules using what I consider regular header pins and it's very loose.
It's not making good contact. Also, jumper wires I put in the C3's expansion header are loose too...
Maybe you're supposed to use extra thick header pins there?
(Maybe I should try to find a part number for the female header and see what is supposed to mate with it...)
  • LeonLeon Posts: 7,620
    edited 2011-09-21 08:13
    Most 2.54 mm spacing headers use 0.64 mm square pins like these:
    http://www.rapidonline.com/Cables-Connectors/Double-row-PCB-header-plug-2-54mm-pitch-28945
  • RaymanRayman Posts: 16,276
    edited 2011-09-21 08:19
    Just measured the pins I'm using and they are 0.64 mm. Yet, they are loose in the C3 expansion header...
    edited 2011-09-21 08:50
    That's strange. I just had a look at the C3 details and it looks like a standard 2x16 connector in the picture.
    The Quickstart boards I have use what looks like a similar connector and a 0.64 mm square header fits that OK.
    edited 2011-09-21 09:03
    Rayman,
    It's all too easy to spring a receptacle's leaves by forcing a too-thick wire or pin into it. Are all the receptacle holes that way, or just some of them?
    edited 2011-09-21 09:21
    It may only be a few not making contact. I'm inserting a board with 10 pins (0.65 mm, gold plated pins).
    It doesn't work unless I push on the board, putting some torque on it to make better contact.
    I'll try cleaning my pins and see if that helps...
    Cleaning my pins with a pencil eraser seems to have fixed the problem...
