Basic Stamp 2pe MoBo "Where to start" ???
WBA Consulting
I just acquired a MoBo setup that consists of the BS2pe MoBo, enclosure, and master 7 segment display. It was being used in a project for work and has since served it's purpose. I now wan to repurpose it as a temp/humidity display by adding in a Sensirion SHT11 sensor.
However, with a little bit of research, I am having trouble gathering a step by step method of implementing a total project with the MoBo. The main program is obviously done simply with the Basic Stamp editor for a 2pe device. However, details on how to utilize the daughter-boards seem to be scattered across different docs, so my progress has gotten a bit rocky. My best guess right now is to bounce between several docs to create a step by step order, but I can't quite make sense of the flow.
So, anyone with MoBo experience have some simple step by step tips for starting off a project like this with the MoBo?
Here's the sequence of documents and downloads I would peruse:
2. 7Seg-DB doc: http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/7Seg-DB_doc(2007.09.05).pdf This explains the 7Seg-DB hardware and how to install it on the MoBo.
3. 7Seg-DB firmware doc: http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/AVR_7SEG1_doc.pdf This explains how to use the 7Seg-DB's AVR firmware driver from PBASIC.
4. LoadAVR.exe: http://www.parallax.com/portals/0/downloads/docs/prod/boards/28300-LoadAVR.zip This is the program you need to load the 7Seg-DB firmware into the "B" AVR chip.
5. 7Seg-DB AVR firmware: http://www.parallax.com/Portals/0/Downloads/src/prod/7SEG1.zip This is the firmware driver that you load into the "B" coprocessor with LoadAVR.
6. Proto-DB doc: http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/28310Proto-DBDoc.pdf This explains the Proto-DB hardware and gives you a layout template to work with. You will use the Proto-DB to accommodate your SHT11 sensor.
7. MoBo extrusion kit doc: http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/MoBoExtrusionKitDocs.pdf This explains how all the parts fit together in the housing.
8. Standalone power appnote: Attached below. (This one seems to have disappeared from the MoBo product page.) How to configure your MoBo's FTDI chip, so it can be powered from one of these: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=T1002-ND
Now, having written this, I can understand your confusion over the plethora of documents necessary to complete your project. If you can suggest a better way to organize this stuff, I'm all eyes and ears.
That's exactly what I was looking for. It sounds like I was heading in the right direction, but wasn't expecting the bunny trail so I thought I was going about it wrong. I will try to run through everything tonight to at least get some numbers up on the 7 segment display. I will need to swing by Parallax to get the ProtoDB to mount the SHT11, but I may just get one of the DB extension cables and wire it to my SHT11 module's terminal block since I am not using Parallax's 8 pin DIP version. I am definitely going to do the FTDI mod so I can power it from USB as well, that is perfect for my project.
As for a better way to organize the MoBo stuff, I think you just nailed it, but could use a visual tweak to get it truly user friendly. Take your post and convert it to a 1 or 2 page quick startup guide with a specific project in mind would make it much easier for people to utilize the MoBo. Maybe even a simple flowchart with each step as a visual since it is actually easy once you understand the whole process. I created a flowchart based on your post and it makes a little bit of sense. Maybe with some pics, it would be even better.
I have deleted the INI file to try it clean a second time, but no change. The MOBO works great running off the USB port and I loaded the "Flash the bicolor LED" code from the MoBo document and it works perfectly, so I know the MoBo is live and talking to the Basic Stamp Editor (version, 2.5.2, on Windows 7 Ultimate.)
My INI file looks like this:
hexfile = C:/Users/Andrew/Documents/parallax/MoBo/7SEG1.HEX
editor = C:/Program Files/Parallax Inc/Stamp Editor v2.5.2/Stampw.exe
Any ideas?
2. Which version of Windows are you using?
3. Which port is your MoBo on?
2) Win7 Ultimate
3) MoBo is showing up on Com6 (after refreshing with MPROG, it is now COM13)
I think that the FTDI programming did not work or messed something up because after cycling power on the MoBo, I cannot get the Basic Stamp Editor to see the BS2pe. I did use FTProg instead of MPROG the first time because FTDI showed that as a newer version. I downloaded MPROG and now I can get the MoBo working again with the BS2 editor. I even flushed the settings back to default to see if that would fix it, but still no luck downloading to the AVRs.
Do I need to power the MoBo from something other than USB to download to the AVRs?
Do I need to mess with other jumpers on the MoBo? (I will open it back up to see how my jumpers are set)
Also, is your system 64-bit?
Attached is LoadAVR v1.5. Try it to see if it works better with your Win7 system.
