[PASM] Get the address
Good Day,
How I get the memory's address without calculate it by hand ?
The code print some string on Lcd and convert the number 389 in ascii
'Can I write #0 without var char ?
How I can return without jump to :done ?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB Main
cognew(@entry, @msg)
repeat ' the spin stops here
dat ' separate dat section to show msg is independent
long
msg byte "Hello ",0 'Test First message
msg2 byte "World !",0,0 'Test second message
buffer res 1
dat org 0
entry mov dira,port 'Config Port I/O
'INIT THE LCD
mov _tmpDelay,#500
Call #Delayms 'Wait for powerUp lcd about 0.5s
Call #lcd_init 'Init Lcd
'READ STRING MSG AND MSG2(#7) FROM MEMORY AND PRINT IT
mov _ndx,par 'read the address of msg to ndx
Call #LcdChar
add _ndx,#7 'I WOULD LIKE GET THE ADDRESS WITHOUT CALCULATE IT BY HAND ( @msg2 ? )
Call #LcdChar
'CONVERT THE NUMBER #389 TO ASCII ( THREE DIGIT ) AND PRINT IT,
'WRITE IT TO MEMORY, READ IT FROM MEMORY AND PRINT IT AGAIN
andn outa,rs 'Get ready for next string
mov cmd,#$C0 'second line
call #LcdDat 'Send command
or outa,rs '
add _ndx,#17 'My buffer start here ( 17th byte ) I WOULD LIKE GET THE ADDRESS WITHOUT CALCULATE IT BY HAND
Call #decToAscii 'Convert #389 to ascii. This is a test ( there is no reverse string)
mov _ndx,par 'read buffer
add _ndx,#17 '
Call #LcdChar 'Print memory contents
:done jmp #:done 'nothing left to do, just jmp #done forever
LcdChar
or outa,RS
:loop rdbyte cmd,_ndx 'read the character from ndx
tjz cmd,#:done 'if the character is 0, exit the loop
Call #LcdDat 'character is not 0, print it
mov _tmpDelay,#511
Call #Delayms
add _ndx, #1 'get the next character address
jmp #:loop 'repeat the loop
:done
LcdChar_ret ret
decToAscii ' TEST
mov number,#389 'this is what I want view on Lcd
:loop
Call #Modulus 'digit = number % 10
mov __x,number 'x = number
mov __y,#10 'y = 10
Call #Divide 'number = number / 10
andn __x,clrW 'Clear remainder ( High word)
mov number,__x 'copy to var number the new value ( number /=10)
mov char,digit 'copy digit to char
add char,#48 'Add '0' to char. The ascii-characters for numbers start at 48 (for 0) up to 57(for 9)
mov cmd,char 'ready to send to Lcd
Call #LcdDat 'Send char to Lcd
wrbyte char,_ndx
add _ndx,#1
tjnz number,#:loop 'if number = 0 Exit
mov char,#0
wrbyte char,_ndx 'I WOULD LIKE WRITE AN IMMEDIATE VALUE ( ZERO )
decToAscii_ret ret
mov char,#0 wrbyte char,_ndx
tjz cmd,#:done :done retThanks in advance
[s] mov _ndx,#msg2 sub _ndx,#msg add _ndx,par[/s]-Phil
mov _ndx,par add _ndx,offset ... offset long @msg2 - @msg-Phil
That way all you have to do is reference the message by number.
It works , Thanks
@Jazzed : yes it would be better, but I dont know what mailbox means, where I can read about it ?
is there an example ?sry I'm learning step by step
Basically you can pass a PAR value to PASM like cognew(@pasm, @value).
The @value is the address of the variable value.
You can use value as an "anchor" for a set of variables - for example: That is a set of variables which can be used as a mailbox.
Now, consider this:
You can read the contents of value and friends in PASM almost the same way you read "msg" before. The problem is in getting the initial address of each message. Here's an example to study.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJOFFSET = $10 PUB start cognew(@entry, @value) repeat ' the spin stops here dat value long @msg+OBJOFFSET ' use address of message + object offset value2 long @msg2+OBJOFFSET value3 long @msg3+OBJOFFSET msg byte "Hello",0 msg2 byte "Hello !",0 msg3 byte "Goodbye.",0 dat org 0 entry again mov msgndx, par ' read the address of value to msgbase mov msgcnt, #3 :loop call #printMsg add msgndx, #4 ' get the next message pointer djnz msgcnt, #:loop jmp #again ' just jmp #again forever printMsg rdlong ndx,msgndx ' read the address of msg to ndx :loop rdbyte text,ndx ' read the character from ndx tjz text, #printMsg_ret ' if the character is 0, exit the loop (# optional) 'Call #LcdDat ' character is not 0, print it 'Call #wait add ndx, #1 ' get the next character address jmp #:loop ' repeat the loop printMsg_ret ret msgndx long 0 ' ndx address messages msgcnt long 0 ' message counter ndx long 0 ' use ndx as an index into the msg array text long 0 ' text to sendIf you are - what looks like - concerned about speed/wasted cycles then you should use something like this:
:loop rdbyte cmd, _ndx [COLOR="orange"]wz[/COLOR] 'read the character from ndx [COLOR="orange"]if_z[/COLOR] jmp :done 'if the character is 0, exit the loopSo in case the jump is taken you spend 4 cycles, in case it's not you only have to worry about a nop (rather than the full jump-not-taken penalty).CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB Main cognew(@String_Lookup, @@0) ' Launch with address stored in par DAT org Message_1 byte "Message 1",00 Message_2 byte "Message 2",00 Message_3 byte "Message 3",00 Message_4 byte "Message 4",00 DAT org String_Lookup or dira,Tx_Mask or outa,Tx_Mask Message_Init mov Temp,#@Message_1 ' #@Message_1 is the address of Message_1 call #Send_Message ' relative to the address of String_Lookup mov UART_Byte,#$0D call #UART_Transmit mov Temp,#@Message_2 call #Send_Message mov UART_Byte,#$0D call #UART_Transmit jmp #Message_Init '----------------------------------------------------------------------- Send_Message add Temp,par ' Add the relative address of the message to the address :Get_Byte ' of String_Lookup to find the absolute address rdbyte UART_Byte,Temp wz if_z jmp Send_Message_ret call #UART_Transmit add Temp,#1 jmp #:Get_Byte Send_Message_ret ret '----------------------------------------------------------------------- UART_Transmit or UART_Byte,#$100 ' Add a stop bit shl UART_Byte,#1 ' Add a start bit mov Bit_Counter,#10 mov cnt,Baud add cnt,#16 add cnt,cnt :Loop shr UART_Byte,#1 wc ' Shift lsb out of Data into C muxc outa,Tx_Mask ' Set / clear the Tx_pin depending on C waitcnt cnt,Baud djnz Bit_Counter,#:Loop ' Loop until ten bits sent UART_Transmit_ret ret '--------------------------------------------------------------------- Tx_Mask long 1<<30 Baud long 694 ' 694 * 0.0125µs = 115,274 bps Temp res 1 Bit_Counter res 1 UART_Byte res 1sry for later answer
@Jazzed :
again mov msgndx, par ' read the address of value to msgbase mov msgcnt, #3 :loop call #printMsg add msgndx, #4 <<<<<< ' get the next message pointer djnz msgcnt, #:loop jmp #again ' just jmp #again foreverI am constrained to know the message 's address but it works thanks@kuroneko: thanks for your tips
:loop rdbyte cmd, _ndx wz 'read the character from ndx if_z jmp :done 'if the character is 0, exit the loop@ChrisGadd : because that @@ is part of Chap 2 Spin Section I haven't read it ( my error )
I will try it thanks
Edit :
It works thanks !
