Electrical Experiment Ideas
For school, we have to design an experiment to follow the scientific method, I've decided to do something about electricity, but I'm not sure what to do. We must follow the scientific method i.e. have a control, independent and dependent variables, hypothesis, conclusion, and other stuff. I can do the experiment with the Basic Stamp if needed and any experiment that can be graphed on Microsoft Excel is better. Please give me your ideas, thank you.
It's presentation would be educational have variation and be timed to a length where people would remain interested and go away with a good impression.
Jeff T.
It might help to know what grade level this is for.
You might look at how different forms of carbon conduct electricity, or not.
Graphite and diamond are pretty good conductors. But what about charcoal or soot? What if you compress the soot or make soot from different sources - candle wax vs. acetylene vs. whatever?
You might look at electrolysis of water - does pulsing the water change the output of gas production?
Does using different types of electrodes alter the gas output?
You might look at the Barkhausen Effect. Look at hooking up a coil to an audio amp so you can listen to the magnetic domains of an iron bar "flip" as you pass a magnet nearby. I suppose you could use a Stamp to create a frequency counter to count how many flips you detect like copper vs. steel, etc.
http://www.youtube.com/watch?v=jy0E3gjm59w
http://en.wikipedia.org/wiki/Barkhausen_Effect
Hint: Salt water yes, distilled water no, chemicals or minerals in water maybe...
... but yet water, distilled or not can be used as a dielectric in-between two 'insulated' parallel plates forming a healthy capacitor. In that case does the water still conduct? ... remember the parallel plates are insulated and submerged in the water. :-)
I think I will stay out of trouble and just leave these two links
http://en.wikipedia.org/wiki/Electrical_conductor
http://en.wikipedia.org/wiki/Dielectric
And maybe this...
http://en.wikipedia.org/wiki/Electron_hole
Bean
Just make sure you know what you are talking about.
Too many people (including some forum members) subscribe to the philosophy...
The answer is no, the outer valance electrons is not acceptable as a conductor. Hydrogen has 1 valence electron, Oxygen has 6 this makes 8 valence electrons, insulators are over 4.
Could you make a processor using digital logic ic's as your project?
