Propeller Assembly for beginners - Page 15 — Parallax Forums
1121315171829
  • LeonLeon Posts: 7,620
    edited 2011-09-01 06:32
    It might work with some switches, you need delays. See:
    http://www.ganssle.com/debouncing.htm
  • HarpritHarprit Posts: 539
    edited 2011-09-01 07:21
    Leon
    I take that by this you mean that the delays provided by the instructions execution themselves are never long enough. (including the time your finger takes).
    The reference was very interesting but if I had to provide a 1/6 second delay to cover all cases, that did seem onerous.
    H
    edited 2011-09-01 07:42
    It's much shorter than that. Read the article properly.
    edited 2011-09-01 07:54
    Typically you can get by with delay of 10 mS to verify the press/release for clean debounce. Most setups I have seen will see a transition, delay 10 ms or so, recheck to see if the state is still the same and accept that a real transition has occured. Some will do this longer as a "did you really mean to press the switch?" test. And yet even longer checks as whe setting values once per press, slow count up/down for short hold press and fast count up/down for longer press and holds.
    Onerous would be trying to chase down mystery behaviors due to poor/missing debounce methods either electronic or in sofgtware. Debounce the UI. Cost $0.00 in software. In hardware a few cents. Continued sanity, priceless.
    Frank
    edited 2011-09-02 13:10
    [FONT=Arial, sans-serif]Here is a bit of code I developed to look at what was going on in the Propeller as I shifted the data left and right and reversed bits etc. As set up now, it lets to look at the data at three locations in the program. It can be expanded to whatever you like.[/FONT]
    [FONT=Arial, sans-serif]The data appears on the PST.[/FONT]
    [FONT=Arial, sans-serif]As set up,the code takes the data in the third byte of a long and reverses the bits. All other bits are erased. Then one erased bit is set. I need to reverse the bits because as my LCD was hooked up to the Propeller, the pins were in the reverse order to what was required.[/FONT]
    [FONT=Arial, sans-serif]It is also useful for looking at what the MUX instructions do.[/FONT]
    [FONT=Arial, sans-serif]H[/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]{{ Program 017 PASM minimum PAR.spin[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]This program is a minimal implementation for two variables and PAR.[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]There are two Cogs in this program, one in SPIN and one in PASM[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Cog 1 in SPIN displays the variables on the console[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Cog 2 in PASM sets the variables [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]Finds the location of PAR and moves it to mem1[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]Then mem2 is set to mem1 +4. [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]The two variables are transferred to mem1 and mem2[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]and become available to the SPIN environment[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]Loop.[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]}}   [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]CON[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]_clkmode = xtal1 + pll16x[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]_xinfreq = 5_000_000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]VAR[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]long eightlongs[3],shared[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]OBJ[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]fds: "FullDuplexSerial"[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]PUB FirstCog                          'displays values on console[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]fds.start(31,30,0,115200)           'start console at 115200 for debug output[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]cognew(@SecondCog, @eightlongs)         'start the second Cog in PASM  [/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]waitcnt(clkfreq/4+cnt)              'wait 1/4 for everything to stabilize.[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]repeat                              'loop  [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared:=eightlongs  [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($1)                        'home to 0,0[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared->=24                                  [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)                   'display first value[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared->=24[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx("_")                   [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)                   'display first value [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx(" ")                   'display first value[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($0d)                        'new line           [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared:=eightlongs[1]  [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]'fds.tx($1)                        'home to 0,0[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($0d)                        'new line[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared:=eightlongs[2]  [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($d)                        'new line[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]'fds.dec(eightlongs[1])        'display second value    [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]waitcnt(clkfreq/60+cnt)            'flicker free wait[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'************************************************************************************************    [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]DAT[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]org    0                          'start at 0 location in the cog [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SecondCog                             'start point identification[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov mem1, par[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov mem2, mem1   [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]add mem2, #4[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov mem3, mem2  [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]add mem3, #4[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]loop      call #start[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]jmp  #loop[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]Start[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov   dira, setdira                       [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov   timer, onesec            '40 000 000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop djnz  timer, #:loop          [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov outa, databyte   [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]wrlong outa, mem1[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop1    djnz  timer, #:loop1[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov outa, databyte[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]shl outa, #16 [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]shr outa, #24  [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]shl outa, #8                 [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]ror outa, #8[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]rev outa, #0[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]ror outa, #16      [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]wrlong outa, mem2 [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop2    djnz  timer, #:loop2                    [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]or    outa,    enablebit  [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]wrlong outa, mem3                         [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]Start_ret  ret          [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]dataByte   long     %00000000_00000000_1001_1110_00000000    [/SIZE][/FONT]
      [FONT=Lucida Console, monospace][SIZE=2]setdira    long    %00000000_00000111_00000000_0000000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SelectBit  long    %00000000_00000100_00000010_00000000 [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]ReadBit    long    %00000000_00000010_00000000_00000000 [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]EnableBit  long    %00000000_00000001_00000000_00000000 [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]onesec     long     80_000_00[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]mem1      res       1           'first address storage space[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]mem2      res       1           'second address storage space[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]mem3      res       1[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]timer     res       1[/SIZE][/FONT]
    edited 2011-09-02 20:43
    @Harprit: Your recent code postings have lost their useful formatting. Simply copying the code into the prop tool isn't working anymore (extra column on the left side). This is not helping people evaluating your stuff.
    Also, your timing loops are confusing. Relative to clkfreq the variable onesec holds the clock count for 1/10th of a second, the comment (40M) suggests 1/2 a second and the actual loop delays for 4/10th of a second. What is it going to be?
    CON
    DAT
    edited 2011-09-05 07:42
    I managed to burn out one of the pins on my propeller as I developed PASM and had one heck of a time figuring out why things would not work. Finally got it replaced so hope to move on now
    However here is the revised code for the program I posted last time with proper commenting and formatting as requested by kuroneko and stephan. These guys keep me honest!
       [FONT=Lucida Console, monospace][SIZE=2]This program allow you to look at data manipulations on PST.[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Cog 1 in SPIN displays the data on the console[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Cog 2 in PASM sets the data and manupulates it[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]Then mem2 is set to mem1 +4. mem3 is set to mem1+8[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]The data is transferred to mem1, mem2 and mem3 where selected by user[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]and become available to the SPIN environment for display[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]}}[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]'shared:=eightlongs[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)     'display first byte[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)     'display second byte [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)     'display third byte[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8)     'display fourth byte[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx(" ")                       [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($0d)                       [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared:=eightlongs[1]  'repeat for second long[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]'fds.tx($1) [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.bin(shared,8) [/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($0d)[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]shared:=eightlongs[2]   'repeat for third long[/SIZE][/FONT]
         [FONT=Lucida Console, monospace][SIZE=2]fds.tx($d)    [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     mem1,    par        'find par address[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     mem2,    mem1       'store it in mem2[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]add     mem2,    #4         'add 4 to mem1 to get second address[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     mem3,    mem1       'store mem1 in mem3[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]add     mem3,    #8         'add 8 to mem1 to get third address[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop     call    #start              'repeating loop[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]jmp     #:loop              '[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]Start    mov     dira,    setdira    'set diretion of DIRA [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     outa,    databyte   'read data into outa[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]wrlong  outa,    mem1       'write result into mem1[/SIZE][/FONT]
                                           [FONT=Lucida Console, monospace][SIZE=2]'[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]shl     outa,    #16        'manupulate outa, shift left 16 to clear bits[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]shr     outa,    #24        'manupulate outa, shift right 24 to celar bits[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]shl     outa,    #8         'manupulate outa, move back to original position [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]ror     outa,    #8         'manupulate outa, rotate to rightmost bits[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]rev     outa,    #0         'manupulate outa, reverse bits[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]ror     outa,    #16        'manupulate outa, rotate back to original bits[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]wrlong  outa,    mem2       'write result into mem[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]or      outa,    enablebit  'manupulate outa[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]wrlong  outa,    mem3       'write result into mem[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'various constants I was using in my particular experiments[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]dataByte   long    %00000110_00011000_10001100_00111000   [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]setdira    long    %00001111_00000111_00001111_00111110[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]mem3      res       1           'third address storage space[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]timer     res       1           'for delays[/SIZE][/FONT]
    edited 2011-09-05 12:37
    I am not sure I understand the reason for using outa for the manipulations of the data as written. It would seem better (not to mention safer for the prop and any attached devices) to create a location in memory to carry out the manipulations. The comment text says that the values resulting from the manipulations will be output via the PST, so any non-spr memory location in the cog could be used to hold/manipulate the data.
    Currently there are no delays or stored results between the manipulations that are taking place, and thus no way to actually see the results at each step; only the end result in the terminal. Consider breaking this into two exercises, one using an internal memory location, and terminal output with additional shared locations to hold/display the intermediate results (with additional text labels indicating the output is for___), and a second using outa, long delays, and perhaps a VERY slow system clock rate so that the results of each manipulation can be seen in the leds. With the caveat the user understands this is only for seeing the effects of the instructions in question as a learning exercise, and not a normal use of outa in practice.
    Frank
    edited 2011-09-05 16:59
    Seconded. Especially with an active dira setup. otherwise it doesn't really matter.
    @Harprit: Wouldn't the following sequence be easier to understand?
    and     outx, mask            ' isolate required byte
            rev     outx, #{32 -}8        ' reverse data
    mask    long    $FF << 8
    edited 2011-09-05 17:33
    As always, you guys are of course right
    My problem is that I am not conversant or comfortable with binary manipulations
    I need to write that chapter now
    This was suggested to me earlier but I did not take the advise as I should have.
    Same ole same ole.
    Will spend time on binary chapter in the next week or so to see if I cant learn something.
    Needs getting done.
    Harprit
    edited 2011-09-05 18:20
    In my beginner primer, there are the very basics of binary manipulations. Get the truth tables and work them on paper. Every one of the Propeller bit operation instructions can be easily written down and processed on paper, one digit at a time, using the truth table. When you've done that, do some addition and subtraction exactly the same way.
    And, or, not, xor, rol, ror, shl, shr, mux (for the prop, and is a cool instruction), rev (again for the prop), are the core of assembly language.
    All of these are not very complex. It's the use cases and short cuts they bring to the table that makes all the difference in the world. Of those the "and, or, shx" instructions see near constant use. They are the ones that break longs into chunks that one can work with and make decisions on.
    http://www.math.grin.edu/~rebelsky/Courses/152/97F/Readings/student-binary
    I would add to that, bit, nibble, byte, word, long, hex, octal, decimal notations and conversions.
    edited 2011-09-11 14:12
    [FONT=Arial, sans-serif]Read the material on binary math.[/FONT]
    [FONT=Arial, sans-serif]Here is what I found specially as being specially relevant to a beginner.[/FONT]
    [FONT=Arial, sans-serif]Binary mathematics are not particularly difficult. However, you have to pay exquisite detail to what you are doing, because beginners do not have a good feel for things that happen as we shift registers to the left and to the right and reverse bits to manipulate the I/O to get the results that we are seeking. It is best to lay it out on paper as you go along.[/FONT]
    [FONT=Arial, sans-serif]At the level that I am working, I am not quite ready to add the shorthand notation that adds even more power to binary manipulations. That absolutely has to come later as the comfort level increases.[/FONT]
    [FONT=Arial, sans-serif]Here is the code for activating a 2 x 16 character liquid crystal display with a standard Hitachi controller. The code is not particularly long, which surprised me, and is not particularly complicated once one figures out what needs to be done. How long it takes to figure out what needs to be done is a whole other matter complicated by that fact that the Hitachi controller manual has some difficult phraseology in it and some of the help material on the internet has mistakes in it.[/FONT]
    [FONT=Arial, sans-serif]I am still not comfortable with the routine that reads the busy bit. Experts please examine and advise. Seems to me that I should not need a delay in this routine.[/FONT]
    [FONT=Arial, sans-serif]Here is the code[/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]{{ Program 019 PASM 2x16 LCD[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]PASM interface for 2x16 LCD[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]This program is a minimal implementation for a  2x16 LCD in PASM[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Cog 1 in SPIN starts PASM Cog[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Cog 2 in PASM sets the LCD up and displays 32 character fill.[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]Connections are[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 13   lcd 11 [/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 14   lcd 12  [/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 15   lcd 13[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 16   lcd 14[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 17   lcd 6 enable[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 18   lcd 5 read/write[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]pin 19   lcd 4 select reg[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]ground   lcd 3[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]power 5V lcd 2[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]ground   lcd 1[/SIZE][/FONT]
       _clkmo[FONT=Lucida Console, monospace][SIZE=2]de = XTAL1 + PLL16x[/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]cognew(@SecondCog, 0)               'start the second Cog in PASM  [/SIZE][/FONT]
       [FONT=Lucida Console, monospace][SIZE=2]waitcnt(clkfreq/4+cnt)              'wait 1/4 for everything to stabilize.  [/SIZE][/FONT]
    [FONT=Lucida Console, monospace][SIZE=2]'oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo   [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     dira,    setdira[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     del_time,   delay_sec       'startup delay[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call    #delay[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop     call    #startLCD          [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     del_time,   delay_sec  [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call    #delay [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]jmp     #:loop[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]StartLCD                       [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0000_0011 [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call    #sendinstr         [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     del_time,  delay5ms [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call    #sendinstr[/SIZE][/FONT]
               call    #sendinst[FONT=Lucida Console, monospace][SIZE=2]r[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0000_0010       'enable 4 bit mode, interface not set. [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'ooooooooooooooooo[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0010_1000       'interface now set to 4 bits [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call    #sendinstr2[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0000_0010       'turn on display [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call    #sendinstr2          [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0000_0110       'cursor motion[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0000_1111       'cursor selection [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov     databits, bits0000_0001       'clear display[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'send out characters to the LCD [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov    counter,  #39[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov    databits,  charA [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]call   #sendchar [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop     add    databits, #264 [/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]sub    counter,  #1  wz [/SIZE][/FONT]
        [FONT=Lucida Console, monospace][SIZE=2]if_nz  jmp    #:loop[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov    counter,  #16[/SIZE][/FONT]
               [FONT=Lucida Console, monospace][SIZE=2]mov    databits,  charQ [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop1    add    databits, #264 [/SIZE][/FONT]
        [FONT=Lucida Console, monospace][SIZE=2]if_nz  jmp    #:loop1        [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]StartLCD_ret     ret  [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]Toggle   or      outa,      enablebit 'hi[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     del_time,  #5[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]andn    outa,      enablebit         'lo[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]Toggle_ret  ret[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]CheckBusyBit[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     dira,     inputs[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]or      outa,     readbit            'hi  [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]andn    outa,     selectbit          'low[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop    andn    ina,   enablebit [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     del_time,   delay160us  [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]andn    ina,  busymask  wz        'or  '  outa,   enablebit [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]CheckBusyBit_ret ret[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'sends instruction as two 4 bit nibbles, high first[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SendInstr2[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]call    #CheckBusyBit[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     outa,    databits [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]andn    outa,    readbit             'lo[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]call    #toggle [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     del_time, delay46us[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]shl     outa,     #4  [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     del_time, delay46us [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SendInstr2_ret    ret  [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]'shifts 4 bits left and send instruction[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SendInstr[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]call    #CheckBusyBit [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]mov     outa,    databits[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SendInstr_ret    ret         [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]Sendchar[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]or     outa,    selectbit            'hi [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]andn   outa,    readbit              'lo [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SendChar_ret  ret[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop   djnz del_time,  #:loop[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay_ret  ret [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay_sec    long    5_000_000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay20ms    long     1_600_000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay5ms     long       400_000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay160us   long        12_800[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay100us   long         8_000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay46us    long         3_680[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]delay1us     long            80[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SetDira      long    %00000000_00001111_1111_1111_00000000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]inputs       long    %00000000_00000111_0000_0000_00000000[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0000_0001  long  %00000000_00000000_0000_0001_00000000 'clear   [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0000_0010  long  %00000000_00000000_0000_0010_00000000 'home [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0000_0011  long  %00000000_00000000_0000_0011_00000000 'clear and home[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0000_0110  long  %00000000_00000000_0000_0110_00000000 'cursor inc, diaploy stays[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0000_1111  long  %00000000_00000000_0000_1110_00000000 'displ on, cursor on, blink off [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0001_1100  long  %00000000_00000000_0001_1100_00000000 'cursor shift right   [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0010_1000  long  %00000000_00000000_0010_1000_00000000 '4 bits, 2 lines, 5x7 dots[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits1000_0000  long  %00000000_00000000_1000_0000_00000000 'busy flag read  [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]bits0000_0000  long  %00000000_00000000_0000_0000_00000000 'zero[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]charA          long  %00000000_00000000_0100_0001_00000000 ' "A"[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]charQ          long  %00000000_00000000_0101_0001_00000000 ' "Q"[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]SelectBit  long  %00000000_00000100_00000000_00000000  'control bits[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]ReadBit    long  %00000000_00000010_00000000_00000000  'control bits [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]EnableBit  long  %00000000_00000001_00000000_00000000  'control bits [/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]busyMask   long  %11111111_11111111_01111111_11111111  'busy bit mask[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]databits    res  1[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]del_time    res  1[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]temp        res  1[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]counter     res  1[/SIZE][/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]alpha_count res  1[/SIZE][/FONT]
    [FONT=Lucida Console, monospace]Harprit
    [/FONT]
    edited 2011-09-11 23:16
    CheckBusyBit
              mov     dira,     inputs
     [COLOR="red"]:loop    andn    ina,   enablebit  [/COLOR]
              call    #delay
              [COLOR="red"]andn    ina,  busymask  wz[/COLOR]        'or  '  outa,   enablebit
       if_nz  jmp     #:loop
              mov     dira,    setdira
    The first line should probably work on outa given that enablebit is a mask which is previously set for output (i.e. inputs & enablebit <> 0) and not be part of the loop. As for the second line, ina needs to in the source slot to be useful here. I'd suggest:
    test    bits1000_0000, ina wz
    under the assumption that busy means not equal zero. Later you might want to get rid of the loop and simply use:
    waitpne bits1000_0000, bits1000_0000        ' wait for high/low transition
    edited 2011-09-12 17:12
    I still am not happy with my check busybit routine in 435. Could some one please rewrite the routine for me. As it is, it works but it seems to me that it should not need the delay.
    H
  • Martin HebelMartin Hebel Posts: 1,239
    edited 2011-09-12 20:01
    A book I always planned on writing but never got around to was a college text on propeller/asm/spin to an extent.
    A good thing to look at is a typical college text, how the architecture is approached for a controller, then getting into ASM and internal peripherals.
    I enjoy teaching the 8051 mainly because of the text - It's extremely important that the CPU & internal hardware is covered since ASM/Machine code ties in so closely to the internals. For the 8051 I use this text - check it out as to a sample approach.
    http://www.amazon.com/8051-Microcontroller-Embedded-Systems-2nd/dp/013119402X/ref=sr_1_1?ie=UTF8&qid=1315882829&sr=8-1
    -Martin
    edited 2011-09-13 08:27
    @Martin
    Please do not expect a college text from me. I have neither the expertise of the desire to do a college text. I hope this will be an introduction for hobbyists, no more no less. I hope it will be an adequate one. So a detailed discussion of the architecture etc does not seem to be in the cards.
    Those interested will take it from there.
    H
    edited 2011-09-13 09:06
    Some further notes on the delay needed in the busybit routine in 435 and 436
    I got to thinking that maybe a delay is needed to allow the
    instruction to complete. Am I right on this?
    Still seems odd to me.
    H
    edited 2011-09-13 17:57
    Harprit wrote: »
    The delay is required because your loop never loops and the delay artificially - I'm guessing here - covers the timeout (that's why it seems to work). This is all because in this context
    will always set the Z flag. You're using ina in the wrong slot (src vs dst). That's why I suggested this earlier:
    edited 2011-09-14 07:47
    [FONT=Arial, sans-serif]@kuroneko[/FONT]
    [FONT=Arial, sans-serif]I tried what you suggested but just could not get it to work.[/FONT]
    [FONT=Arial, sans-serif]However this does work[/FONT]
     [FONT=Lucida Console, monospace][SIZE=2]:loop    mov    temp,     ina[/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]or      outa,      enablebit         'hi          [/SIZE][/FONT]
              [FONT=Lucida Console, monospace][SIZE=2]test    bits1000_0000, temp wz     [/SIZE][/FONT]
    [FONT=Arial, sans-serif]But I still need the delay and the delay cannot be less[/FONT]
    [FONT=Arial, sans-serif]I still cannot get it right in my mind.[/FONT]
    As a matter of fact the only thing that matters is the delay.
    Everything else can be deleted. So the BUSY flag is not being read
    [FONT=Arial, sans-serif]HSS[/FONT]
    edited 2011-09-14 13:08
    I have come to the conclusion that I am not reading the busy bit right.
    I need someone to explain it in detail to me.
    What should be set to what when etc. or a code listing would help.
    Everything works fine with a delay but tha's not the goal here.
    H
    edited 2011-09-14 13:17
    The data sheet says that the condition of the BB can be read by making the register select line low and the read/write bit high. The BB is available when the enable bit is made low.
    After that if I read ina into temp can I isolate the bit from that? I am having difficulty with that. Apparently I am doing something wrong.
    H
  • JonnyMacJonnyMac Posts: 9,373
    edited 2011-09-14 15:15
    Harprit wrote: »
    I haven't finished porting my [ working ] Spin LCD driver to PASM, but this is the port of the code that waits for the busy flag to clear -- perhaps it will help you.
    Here's the working Spin routine:
    pub waitbusy | addr
    '' Reads busy flag and cursor address
    '' -- returns cursor address when busy flag has cleared
      dira[db7..db4] := %0000                                       ' make buss pins inputs
      outa[rs] := 0                                                 ' command mode
      outa[rw] := 1                                                 ' read
      repeat
        outa[e] := 1                                                ' request bf + high nib
        addr := ina[db7..db4] << 4                                  ' bf + high nib of address
        outa[e] := 0                                                ' finish nib read
        outa[e] := 1                                                ' request low nibble
        addr |= ina[db7..db4]                                       ' low nib of address
        outa[e] := 0
      while (addr & %1000_0000)                                     ' check busy flag
      return addr
    And here's my PASM conversion:
    ' waits for busy flag to clear
    ' -- leaves cursor address in "crsrpos"
    wait_busy               andn    dira, bussmask                  ' make buss pins inputs
                            andn    outa, rsmask                    ' low  (command)
                            or      outa, rwmask                    ' high (read)
    :loop                   or      outa, emask                     ' e pin high
                            mov     delay, #1                       ' 1us delay
                            call    #us_delay
                            mov     tmp1, ina                       ' get bf + high bits of address
                            and     tmp1, bussmask                  ' mask off non-buss pins
                            shr     tmp1, db4pin                    ' align lsb
                            shl     tmp1, #4                        ' move to high nib position
                            mov     crsrpos, tmp1                   ' copy to result
                            andn    outa, emask                     ' e pin low
                            call    #us_delay
                            call    #us_delay
                            mov     tmp1, ina                       ' get low nib of address
                            and     tmp1, bussmask
                            shr     tmp1, db4pin
                            or      crsrpos, tmp1                   ' add low nib
                            call    #us_delay
                            test    crsrpos, BIT7           wc      ' check busy flag
            if_c            jmp     #:loop                          ' wait until busy clears
    wait_busy_ret           ret
    When the object is finished and testing I'll post in ObEx.
  • RinksCustomsRinksCustoms Posts: 531
    edited 2011-09-14 19:59
    StefanL38 wrote: »
    Hi Harprit,
    take a look at PASD the propeller assembly debugger http://insonix.ch/propeller/prop_pasd.html
    The website is german but the manual is in english.
    With this tool you can single-step through PASM-code and lookup the value of each long in the COG-RAM.
    very helpful for analysing what is going on.
    keep the questions coming
    best regards
    Stefan
    if using chrome when you goto your link up top near the address bar, google asks you if you want to translate the page from German. Does a pretty good job. I use chrome to make sense of Chinese/Taiwan/Japan web pages..
  • ChrisGaddChrisGadd Posts: 311
    edited 2011-09-15 05:49
    I still consider myself something of a noob with the propeller, though I already had experience with assembly in other micros (SX28, 8051, PIC16) when I started, though that also gave me some preconceptions to deal with on the prop. The issues that I had the most trouble wrapping my mind around were working without interrupts, calling subroutines without having a stack to push or pop, literals being limited to less than the full value of the register--having to store a constant value in a variable if it exceeds nine bits, and figuring out how the prop handles indirect addressing through self-modifying code, and memory management between the hub and the cogs. The octothorpe # still manages to bite me on the butt occasionally.
    Reading through this thread has also shown me a few tricks that I missed, so it's been a help for me already. One concern I have is your reliance on pre-compiled objects, specifically the FullDuplexSerial object. It's a wonderful object, no doubt, but I vastly prefer building my own objects so I know exactly how it works, and a UART is a really simple routine, good for a beginner, if you don't try to make it too fancy right away.
    I go through the same basic routines whenever I pick up a new microcontroller; start be flashing a LED, flashing at a calculated frequency, building a binary LED counter, a ring counter, etc, just to get a feel for manipulating bits. Next I'll try reading pins, measuring a RC circuit and lighting LEDs depending on the time it takes to charge. After that it's usually a UART transmitter (having an o'scope admittedly does make this easier), and once the UART transmitter is displaying "A"s I'll create a string lookup routine to display messages, then a HEX to ASCII routine so I can display a counter, and a HEX to BCD to ASCII routine to see the counters in decimal. Then I get into stuff like a SPI driver for reading an ADC chip, I2C for reading and writing to the EEPROM, and parallel LCD drivers.
    And on that note, here's the guts of a routine I managed to whip up yesterday, inspired by this thread. Hopefully the formatting doesn't get mangled again; it looks fine in preview.
    {{Parallel LCD Driver
    The LCD D4, D5, D6, D7 lines must be connected to sequential pins on prop in the same order
    To execute an instruction (CLS, move cursor...):
      load the instruction into LCD_Byte
      jmpret Return_add,#LCD_Command
    To display a character:
      load the character into LCD_Byte
      jmpret Return_add,#LCD_Text
    CON
    E_Pin = 19
    RW_Pin = 18
    RS_Pin = 17
    D4_Pin = 20
    D7_Pin = D4_Pin + 3
    LCD_Offset = D4_Pin
    PUB Main
      cognew(@LCD_Init, 0)
    DAT                     org
    LCD_Init
                            or        dira,LCD_mask
                            or        dira,E_mask
                            or        dira,RW_mask
                            or        dira,RS_mask
                            mov       LCD_Temp,#%0010             ' 4-bit mode
                            call      #LCD_Send_Nibble
                            mov       LCD_Byte,#%0010_1000        ' 4-bit mode, 2-line, 5x8 pixel characters
                            mov       LCD_Byte,#%0000_1100        ' Turn display on, no cursor
                            mov       LCD_Byte,#%0000_0001        ' Clear LCD
    'Display_Messages
                            mov       LCD_Byte,#"H"
                            mov       LCD_Byte,#"i"
                            mov       LCD_Byte,#%1100_0000        ' Line 2 column 1
                            mov       LCD_Byte,#"W"
                            mov       LCD_Byte,#"o"
                            mov       LCD_Byte,#"l"
                            mov       LCD_Byte,#"d"
                            mov       LCD_Byte,#"!"
                            jmp       #$
    LCD_Command
                            call      #Check_Busy_Flag
    '                       andn      outa,RS_mask                ' Send a command
                            jmp       #LCD_Prepare_Byte
    LCD_Text
                            or        outa,RS_mask                ' Send text
    LCD_Prepare_Byte
                            mov       LCD_Temp,LCD_Byte           ' Make a copy of the LCD_Byte
                            shr       LCD_Temp,#4                 ' Move high nibble into low nibble location
                            call      #LCD_Send_Nibble            ' Send fist nibble
                            mov       LCD_Temp,LCD_Byte           ' Reload LCD_Byte
                            call      #LCD_Send_Nibble            ' Send second nibble
                            jmp       Return_add
    LCD_Send_Nibble
                            and       LCD_Temp,#$0F               ' Preserve the low nibble
                            shl       LCD_Temp,#LCD_offset        ' Move the low nibble to the LCD pin locations
                            andn      outa,LCD_mask               ' Clear the LCD pins
                            or        outa,LCD_Temp               ' Update the LCD pins
                            call      #Clock
    LCD_Send_Nibble_ret     ret
    Check_Busy_Flag
                            andn      dira,D7_mask                ' Make D7 an input
                            andn      outa,RS_mask                ' Command mode
                            or        outa,RW_mask                ' Read mode
    :Loop
                            call      #Clock                      ' Clock the Enable line
                            test      D7_mask,ina           wz    ' Read the busy flag
                            call      #Clock                      ' Clock again for the low nibble
              if_ne         jmp       #:Loop                      ' Loop until busy flag goes low
                            or        dira,D7_mask                ' Make D7 an output
                            andn      outa,RW_mask                ' Write mode
    Check_Busy_Flag_ret     ret
    Clock
                            or        outa,E_mask
                            mov       Delay_cnt,#5                ' 250ns delay
                            djnz      Delay_cnt,#$
                            andn      outa,E_mask
    Clock_ret               ret
    RS_mask                 long      1<<RS_pin
    E_mask                  long      1<<E_pin
    RW_mask                 long      1<<RW_pin
    D7_mask                 long      1<<D7_pin
    LCD_mask                long      $F<<LCD_Offset
    LCD_Byte                res       1
    LCD_Temp                res       1
    Return_add              res       1
    Delay_cnt               res       1
    edited 2011-09-15 06:44
    @Jon
    I had read your OBEX you sited above but could not convert it to PASM successfully. Of course I think I can now! Thanks.
    Why do we need the delays you have inserted in the PASM routine?
    H
    edited 2011-09-15 06:51
    @Chris
    We need to be able to look at things as we go along. I use the FDS object for its ease of use by a beginner. I stick with using FDS to keep it simple. As beginners we are not capable of creating something like the FDS or even a simpler version right now. May be later.
    I could not agree more with you on the difficulties you had getting going with the PASM. I have had pretty much the same problems myself. Good to know that we share that! I am making a special effort to cover these areas in the book in that I am sure beginners will share our experiences.
    I'll take a careful look at your code. Thanks
    HSS.
    edited 2011-09-15 11:36
    According to the HD44780 data sheet (hint, hint), the minimum time before data is ready after the rising edge of the E pin is 160ns (0.16us). As my code has a delay routine that works in microseconds, I'm using the minimum delay; it's more than required which will not hurt anything.
  • koehlerkoehler Posts: 598
    edited 2011-09-15 23:38
    I did a quick google for assembler and dummies, and found this site.
    Disregard, I see you're past that.
    edited 2011-09-16 12:26
    @Jon
    I am sensitive and accepting of the the fact that the data sheets need to be read and understood.
    I have/had the data sheet in front of me as I programmed the LCD. The way I read it, it clearly says that there is no wait required for reading the busy flag. And after that all instructions can be executed one after the other, as I understand it, and as worked just fine for my implementation of the LCD. The executions time delays apply only to the initialization sequence. But obviously I have it wrong. What am I not under standing right and where is the information I am skipping or misunderstanding. I feel that this is important to my proper understanding of reading the data sheets and so I ask for your further help.
    H
    edited 2011-09-17 07:42
    Look in the timing diagrams. You will see that there is an offset between the low-to-high transition on E and having valid data on the buss. In the docs I'm using -- the original HD44780 data sheet on which most character LCDs are based -- Figure 28 (pdf page 59) shows buss read timing. The delta from E high to data ready is called Tddr; you can find the spec on pdf page 53 -- 160ns max.
