Television analog audio — Parallax Forums
Vega256Vega256 Posts: 197
edited 2011-08-31 05:25 in Propeller 1
What type of hardware connection is required to transmit analog audio to the television through stereo RCA connectors?
    edited 2011-08-15 14:08
    With a DUTY mode output from a counter, an RC low-pass filter is adequate. 560 ohms and 0.1 uF should work okay.
    edited 2011-08-15 18:07
    And you will require a dc isolation cap, 4.7uF-10uF. Electrolytic is fine.
    You will need to duplicate this circuit for the second channel.
    Look at Ahle's SIDcog thread (its currently on the first or second page of this forum at the moment).
  • Vega256Vega256 Posts: 197
    edited 2011-08-31 05:06
    Can someone help me locate the schematic for the SIDcog or any other audio output circuit?
    Vega256: Here is my circuit values. C2 should be 4.7uF-10uF. BTW you should start a new thread for this.
