Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Television analog audio — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Vega256
197
2011-08-15 14:00
edited 2011-08-31 05:25
in
Propeller 1
What type of hardware connection is required to transmit analog audio to the television through stereo RCA connectors?
Phil Pilgrim (PhiPi)
23,514
2011-08-15 14:08
edited 2011-08-15 14:08
With a DUTY mode output from a counter, an RC low-pass filter is adequate. 560 ohms and 0.1 uF should work okay.
Cluso99
18,069
2011-08-15 18:07
edited 2011-08-15 18:07
And you will require a dc isolation cap, 4.7uF-10uF. Electrolytic is fine.
You will need to duplicate this circuit for the second channel.
Look at Ahle's SIDcog thread (its currently on the first or second page of this forum at the moment).
Vega256
197
2011-08-31 05:06
edited 2011-08-31 05:06
Can someone help me locate the schematic for the SIDcog or any other audio output circuit?
Cluso99
18,069
2011-08-31 05:25
Vega256: Here is my circuit values. C2 should be 4.7uF-10uF. BTW you should start a new thread for this.
891 x 499
52K
52.1K
Sign In
Register
to comment.
