Parallax Balance Bot
I may be a little wrong on some things.
I have a Us Digital rotory encoder from LynxMotion QME-01
Im using a BS2 MCU.
Memsic 2125 accelerometer
Lisy300 gyro
HB25 motor controllers
Currently all the parts arent being used.I tried creating different code for each at different times with no sucsess.
post # 9 is probably the most functional example of proportional
When power is applied to the motor Im gettn a reading but when the motor stops the encoder resets back to zero.
I'd like to keep the variable from reseting back to zero?
This is part of a balance bot project.I have parts of code and changes made to the original design ie.I switched out the LMD 18200 H bridges for HB25 motor controllers
.I need help compiling it all together.Possiblily with a PID loop.
here are more bits of code that need adjustment.
Im out of time for now (off to work) I know its messed
here is sample PID loop info any help I can get with setting scales and algorithms would be excellent!!!
http://forums.parallax.com/showthread.php?77656
Im using a BS2 MCU.
Lisy300 gyro
' {$STAMP BS2} ' {$PBASIC 2.5} ' HomeBrew-Gyro-Tilt-levellights-encoder-debug.bs2 ' Measure room temperature tilt,and give gyro reading in x plane.level indicator lights. ' -----[ I/O Definitions ]------------------------------------------------- Dout PIN 0 ' P0 <-- Dout (LISY300.2) SCLK PIN 1 ' P1 --> SCLK (LISY300.4) CSn PIN 2 ' P2 --> /CS (LISY300.5) tiltx PIN 6 ' memsic 2125 X axis tilty PIN 7 ' memsic 2125 Y axis encoderA PIN 9 'Lynx Motion motor encoder QME-01 encoderB PIN 8 'Lynx Motion motor encoder QME-01 BiColorledGREEN PIN 13 ' x axis down light led green when high and low 12 BiColorledRED PIN 12 ' x axis up light led red when high and low 13 ' -----[ Constants ]------------------------------------------------------- Yes CON 1 ' Yes Constant No CON 0 ' No Constant ' -----[ Variables ]------------------------------------------------------- value VAR Word ' ADC Result Value x VAR Word y VAR Word a VAR Word b VAR Word ' -----[ EEPROM Data ]----------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- Initialization: HIGH CSn LOW SCLK PAUSE 250 ' -----[ Program Code ]---------------------------------------------------- Main: DO GOSUB Read_Gyro DEBUG "ADC Value:", DEC5 value PAUSE 250 PULSIN 9, 1, a PULSIN 8, 1, b PULSIN 6, 1, x PULSIN 7, 1, y IF x > 2525 THEN HIGH 13: LOW 12 ' x axis down light led 1 green IF x < 2525 THEN LOW 13: HIGH 12 ' x axis up light led 2 red IF x = 2525 THEN PAUSE 250 DEBUG CLS, ? X, ? Y, ? a, ? b PAUSE 100 LOOP STOP ' -----[ Subroutines ]----------------------------------------------------- Read_Gyro: LOW CSn SHIFTIN Dout, SCLK, MSBPOST, [value\13] HIGH CSn RETURN
' {$STAMP BS2} ' {$PBASIC 2.5} ' HomeBrew-Gyro-Tilt-motor-encoder-debug.bs2 ' Measure room temperature tilt,and give gyro reading in x plane. ' -----[ I/O Definitions ]------------------------------------------------- Dout PIN 0 ' P0 <-- Dout (LISY300.2) SCLK PIN 1 ' P1 --> SCLK (LISY300.4) CSn PIN 2 ' P2 --> /CS (LISY300.5) tiltx PIN 6 tilty PIN 7 encoderA PIN 9 encoderB PIN 8 motorpowr PIN 15 ' motor power motorDir PIN 14 ' motor direction ' -----[ Constants ]------------------------------------------------------- Yes CON 1 ' Yes Constant No CON 0 ' No Constant ' -----[ Variables ]------------------------------------------------------- value VAR Word ' ADC Result Value x VAR Word y VAR Word a VAR Word b VAR Word ' -----[ EEPROM Data ]----------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- Initialization: HIGH CSn LOW SCLK PAUSE 250 ' -----[ Program Code ]---------------------------------------------------- Main: DO GOSUB Read_Gyro DEBUG "ADC Value:", DEC5 value PAUSE 10 HIGH 15 PAUSE 100 LOW 15 PAUSE 150 PULSIN 9, 1, a PULSIN 8, 1, b PULSIN 6, 1, x PULSIN 7, 1, y IF x > 2525 THEN HIGH 14 IF x < 2525 THEN LOW 14 IF x = 2525 THEN PAUSE 250 DEBUG CLS, ? X, ? Y, ? a, ? b PAUSE 10 LOOP STOP ' -----[ Subroutines ]----------------------------------------------------- Read_Gyro: LOW CSn SHIFTIN Dout, SCLK, MSBPOST, [value\13] HIGH CSn RETURN
' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[ Program Description ]--------------------------------------------- ' This program tests the HB-25 by waiting for it to power up, then pulsing ' the output to ramp the motors up in opposite directions, wait 3 seconds ' then ramp them back down to a stopped position. While the code is ' written for two HB-25/motors you can use it with just one by commenting ' out or removing the lines for the second motor, commented below. If you ' have two HB-25/motors connected, remember to remove the jumper block from ' the second HB-25. ' -----[ I/O Definitions ]------------------------------------------------- HB25 PIN 15 ' I/O Pin For HB-25 ' -----[ Variables ]------------------------------------------------------- index VAR Word ' Counter For Ramping x VAR Word y VAR Word a VAR Word b VAR Word ' -----[ Initialization ]-------------------------------------------------- DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up LOW HB25 ' Make I/O Pin Output/Low PAUSE 5 ' Wait For HB-25 To Initialize PULSOUT HB25, 750 ' Stop Motor 1 PAUSE 1 ' 1 mS Delay PULSOUT HB25, 750 ' Stop Motor 2 (If Connected) ' The Above 2 Lines May Be Removed ' If You Are Using Single Mode ' -----[ Program Code ]---------------------------------------------------- Main: DO PAUSE 20 ' Wait 20 mS Before Ramping PULSIN 9, 1, a PULSIN 8, 1, b PULSIN 6, 1, x PULSIN 7, 1, y DEBUG CLS, ? X, ? Y, ? a, ? b FOR index = 0 TO 250 ' Ramp Up To Full Speed PULSOUT HB25, 750 + index ' Motor 1 Forward PAUSE 1 ' 1 mS Delay For Motor 2 Pulse PULSOUT HB25, 750 - index ' Motor 2 Reverse PAUSE 20 ' 20 mS Smoothing Delay NEXT PAUSE 3000 ' Wait 3 Seconds FOR index = 250 TO 0 ' Ramp Back Down PULSOUT HB25, 750 + index ' Motor 1 Forward Slowing PAUSE 1 ' 1 mS Delay For Motor 2 PULSOUT HB25, 750 - index ' Motor 2 Reverse Slowing PAUSE 20 ' 20 mS Smoothing Delay NEXT LOOP
PULSIN measures the width of an incoming pulse train and therefore can measure speed (or some other value) by watching the width of the pulses coming in. BUT, if the pulses are too far apart or too large (like when the shaft has stopped, they go to zero). Trying to store the value in EEPROM will not help. As well, if the pulses get too fast, there comes a point the Stamp can't process the value. More detail is available in the Helpfile.
Cheers,
I wanna see your balance bot in action, a subject near & dear to my heart!
http://36ohk6dgmcd1n.yom.mail.yahoo.net/om/api/1.0/openmail.app.invoke/36ohk6dgmcd1n/4/1.0.35/us/en-US/view.html#
http://forums.parallax.com/showthread.php?121179-Reading-Quadrature-Encoders
in tryn to use this code with a added DEBUG line im getting errors
2515 is level divide that by 3.35 it gives me about 750 which is used to control the motor.
as is,it seems to work right but only as if like 2250 were level
I added - 93 and it works more at level but LOL its goes the opposite direction any suggestions?fixed
also added a drive variable that displays the pulsout value used to drive the motors and debug setpoint,error,and drive values
Are you modeling your robot after someone else's? Tough project from scratch. I made a thread with lots of links to other balance bots: http://forums.parallax.com/showthread.php?126312-Balancing-Bot&highlight=balancing+bot Check out those references.
original edited
example two on integral
you cant simply change Change the drive = i statement to drive = i + Offset MIN 650 MAX 850.
√······· Run the program and verify that the integral output is limited to values between 650 and 850.· Try entering 2 repeatedly, then -2 repeatedly.
Offset hasnt been declared.
so offset = ?
You cant use offset = ? either
so i have
drive = i + setpoint - current MIN 650 MAX 850
is this correct?
the drive value is a proportional acc. reading
now Im looking to have the gyro feed the derivative portion of the PID loop?Oh boy...
Yours,
Captain Obvious
http://forums.parallax.com/showthread.php?126312-Balancing-Bot&p=965006&viewfull=1#post965006
