Parallax Balance Bot — Parallax Forums
graffixgraffix Posts: 389
edited 2012-01-24 11:21 in BASIC Stamp
I may be a little wrong on some things.
I have a Us Digital rotory encoder from LynxMotion QME-01
Im using a BS2 MCU.
Memsic 2125 accelerometer
Lisy300 gyro
HB25 motor controllers
Currently all the parts arent being used.I tried creating different code for each at different times with no sucsess.
post # 9 is probably the most functional example of proportional
When power is applied to the motor Im gettn a reading but when the motor stops the encoder resets back to zero.
I'd like to keep the variable from reseting back to zero?
' {$STAMP BS2}
' {$PBASIC 2.5}
' HomeBrew-Gyro-Tilt-levellights-encoder-debug.bs2
' Measure room temperature tilt,and give gyro reading in x plane.level indicator lights.
' -----[ I/O Definitions ]-------------------------------------------------
Dout             PIN     0               ' P0 <-- Dout (LISY300.2)
SCLK             PIN     1               ' P1 --> SCLK (LISY300.4)
CSn              PIN     2               ' P2 --> /CS  (LISY300.5)
tiltx            PIN     6               ' memsic 2125 X axis
tilty            PIN     7               ' memsic 2125 Y axis
encoderA         PIN     9               'Lynx Motion motor encoder QME-01
encoderB         PIN     8               'Lynx Motion motor encoder QME-01
BiColorledGREEN  PIN     13              ' x axis down light led green when high and low 12
BiColorledRED    PIN     12              ' x axis up light led red when high and low 13
' -----[ Constants ]-------------------------------------------------------
Yes             CON     1               ' Yes Constant
No              CON     0               ' No Constant
' -----[ Variables ]-------------------------------------------------------
value           VAR     Word            ' ADC Result Value
x               VAR     Word
y               VAR     Word
a               VAR     Word
b               VAR     Word
' -----[ EEPROM Data ]-----------------------------------------------------
' -----[ Initialization ]--------------------------------------------------
Initialization:
  HIGH CSn
  LOW SCLK
  PAUSE 250
' -----[ Program Code ]----------------------------------------------------
Main:
  DO
    GOSUB Read_Gyro
      DEBUG "ADC Value:", DEC5 value
    PAUSE 250
    PULSIN 9, 1, a
    PULSIN 8, 1, b
    PULSIN 6, 1, x
    PULSIN 7, 1, y
      IF x > 2525 THEN HIGH 13: LOW 12        ' x axis down light led 1 green
      IF x < 2525 THEN LOW 13: HIGH 12         ' x axis up light led 2 red
      IF x = 2525 THEN PAUSE 250
    DEBUG CLS, ? X, ? Y, ? a, ? b
    PAUSE 100
  LOOP
  STOP
' -----[ Subroutines ]-----------------------------------------------------
Read_Gyro:
  LOW CSn
  SHIFTIN Dout, SCLK, MSBPOST, [value\13]
  HIGH CSn
  RETURN
This is part of a balance bot project.I have parts of code and changes made to the original design ie.I switched out the LMD 18200 H bridges for HB25 motor controllers :).I need help compiling it all together.Possiblily with a PID loop.
here are more bits of code that need adjustment.
' {$STAMP BS2}
' {$PBASIC 2.5}
' HomeBrew-Gyro-Tilt-motor-encoder-debug.bs2
tiltx           PIN     6
tilty           PIN     7
encoderA        PIN     9
encoderB        PIN     8
motorpowr       PIN     15              ' motor power
motorDir        PIN     14              ' motor direction
x               VAR     Word
y               VAR     Word
a               VAR     Word
b               VAR     Word
Initialization:
  HIGH CSn
  LOW SCLK
  PAUSE 250
Main:
  DO
    GOSUB Read_Gyro
      PAUSE 10
      HIGH 15
      PAUSE 100
      LOW 15
      PAUSE 150
    PULSIN 9, 1, a
    PULSIN 8, 1, b
    PULSIN 6, 1, x
    PULSIN 7, 1, y
      IF x > 2525 THEN HIGH 14
      IF x < 2525 THEN LOW 14
    PAUSE 10
  LOOP
  STOP
Read_Gyro:
  LOW CSn
  HIGH CSn
  RETURN
'   {$STAMP BS2}
'   {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' This program tests the HB-25 by waiting for it to power up, then pulsing
' the output to ramp the motors up in opposite directions, wait 3 seconds
' then ramp them back down to a stopped position.  While the code is
' written for two HB-25/motors you can use it with just one by commenting
' out or removing the lines for the second motor, commented below.  If you
' have two HB-25/motors connected, remember to remove the jumper block from
' the second HB-25.
HB25            PIN     15              ' I/O Pin For HB-25
index           VAR     Word            ' Counter For Ramping
x               VAR     Word
y               VAR     Word
a               VAR     Word
b               VAR     Word
DO : LOOP UNTIL HB25 = 1                ' Wait For HB-25 Power Up
LOW HB25                                ' Make I/O Pin Output/Low
PAUSE 5                                 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750                       ' Stop Motor 1
PAUSE 1                                 ' 1 mS Delay
PULSOUT HB25, 750                       ' Stop Motor 2 (If Connected)
                                        ' The Above 2 Lines May Be Removed
                                        ' If You Are Using Single Mode
Main:
 DO
  PAUSE 20                              ' Wait 20 mS Before Ramping
  PULSIN 9, 1, a
    PULSIN 8, 1, b
    PULSIN 6, 1, x
    PULSIN 7, 1, y
  FOR index = 0 TO 250                  ' Ramp Up To Full Speed
    PULSOUT HB25, 750 + index           ' Motor 1 Forward
    PAUSE 1                             ' 1 mS Delay For Motor 2 Pulse
    PULSOUT HB25, 750 - index           ' Motor 2 Reverse
    PAUSE 20                            ' 20 mS Smoothing Delay
  NEXT
  PAUSE 3000                            ' Wait 3 Seconds
  FOR index = 250 TO 0                  ' Ramp Back Down
    PULSOUT HB25, 750 + index           ' Motor 1 Forward Slowing
    PULSOUT HB25, 750 - index           ' Motor 2 Reverse Slowing
  NEXT
 LOOP
Im out of time for now (off to work) I know its messed
here is sample PID loop info any help I can get with setting scales and algorithms would be excellent!!!
http://forums.parallax.com/showthread.php?77656
  • stamptrolstamptrol Posts: 1,731
    edited 2011-07-27 12:55
    I think you're expecting something different from the PULSIN command than its meant to deliver.
    PULSIN measures the width of an incoming pulse train and therefore can measure speed (or some other value) by watching the width of the pulses coming in. BUT, if the pulses are too far apart or too large (like when the shaft has stopped, they go to zero). Trying to store the value in EEPROM will not help. As well, if the pulses get too fast, there comes a point the Stamp can't process the value. More detail is available in the Helpfile.
    Cheers,
  • graffixgraffix Posts: 389
    edited 2011-07-27 14:39
    Thanks Tom.
  • ercoerco Posts: 20,260
    edited 2011-07-27 16:14
    graffix: Per Tom, there is a timeout on pulse width when using PULSIN, which varies by stamp flavor: 131 ms for vanilla BS2 vs. 53 ms for a BS2P.
    I wanna see your balance bot in action, a subject near & dear to my heart!
    edited 2011-07-28 10:35
    It works slightly with just the memsic and the HB25's
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    tiltx           PIN     6
    tilty           PIN     7
    encoderA        PIN     9
    encoderB        PIN     8
    HB25            PIN     15              ' motor power
    bicolorledgreen PIN     12              ' motor direction
    bicolorledred   PIN     13
    x               VAR     Word
    y               VAR     Word
    a               VAR     Word
    b               VAR     Word
    Initialization:
      HIGH CSn
      LOW SCLK
      PAUSE 250
    Main:
      DO
        GOSUB Read_Gyro
          PAUSE 10
          LOW 15
          PAUSE 5
        PULSIN 9, 1, a
        PULSIN 8, 1, b
        PULSIN 6, 1, x
        PULSIN 7, 1, y
          IF x > 2525 THEN PULSOUT 15,650 : HIGH 12 : LOW 13
          IF x < 2525 THEN PULSOUT 15,850 : HIGH 13 : LOW 12
        PAUSE 10
      LOOP
      STOP
    Read_Gyro:
      LOW CSn
      HIGH CSn
      RETURN
    edited 2011-07-30 04:48
    well, per this Im gonna have to use at least a BS2sx to be able to read the encoders?
    http://forums.parallax.com/showthread.php?121179-Reading-Quadrature-Encoders
    in tryn to use this code with a added DEBUG line im getting errors
    ' {$stamp bs2}
    ' Program to act as high speed quadrature counter
    ' Program Name: quadhicount.bs2
    ' Last Update: Mar 10/01 tjs
    DIRH=%11111111
    counter VAR Word
    counter2 VAR Word
    counter3 VAR Word
    old VAR Nib
    new VAR Nib
    direct VAR Byte
    ' Channel a and b of encoder go on inputs 4 and 5 in this case.
    quad:
       counter=127         'load a dummy value so can count up or down
       new = INB & %0011      ' get initial condition
    start:
       old = new & %0011      ' remember initial setting
    again:
       new = INB & %0011      ' get new reading
       IF new=old THEN again
       direct=new.BIT1 ^ old.BIT0   ' XOR left bit of new with right bit of old to get direction
       IF direct=1 THEN cw      ' jump here to increment
       LOW 0                    ' pin 0 turns led off id turning counter-clockwise
       counter=counter-1         ' jump here to decrement
       OUTH=counter.LOWBYTE
       DEBUG HOME, DEC3 counter
       GOTO start
    cw:
       HIGH 0   ' pin 0 turns on led if turning clockwise
       counter=counter+1
       OUTH=counter.LOWBYTE  'turn on leds on pins 8 through 15 to watch count
       GOTO start
    edited 2011-08-25 22:12
    I have something close I think, but I'd like the Kp value to be 3.35 but it wont accept the decimal digits.How can I change it?
    2515 is level divide that by 3.35 it gives me about 750 which is used to control the motor.
    as is,it seems to work right but only as if like 2250 were level
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    tiltx          PIN       6
    hb25           PIN       15
    '---Variable----
    x              VAR       Word
    ' ---Constants---
    Kp         CON    3
    SetPoint    CON    2515
    '---Main---
    DO
      PULSIN 6,1,x
      DEBUG CLS, ? X, ? 15
      PULSOUT 15, x / Kp
      PAUSE 100
    LOOP
    edited 2011-08-25 23:07
    This is about the closet Ive come it only uses the proportional part of the PID loop and might work well with a super light bot with continuous rotation servos
    I added - 93 and it works more at level but LOL its goes the opposite direction any suggestions?fixed
    also added a drive variable that displays the pulsout value used to drive the motors and debug setpoint,error,and drive values
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    tiltx          PIN       6
    hb25           PIN       15
    '---Variable----
    x              VAR       Word
    drive          VAR       Word
    error          VAR       Word(2)
    ' ---Constants---
    Kp         CON    3
    SetPoint    CON    2543
    '---Main---
    DO
      drive = x / Kp -93
      error = x - setpoint
      PULSIN 6,1,x
      DEBUG CLS, ? setpoint, ? X, ? error, ? drive
      PULSOUT 15, drive
      PAUSE 100
    LOOP
    edited 2011-08-25 23:48
    Well I solved it I switched the leads to the motors. It needs more though the rate at which Im falling is to much to compansate?Hmm...Maybe the gyro or I need more of the PID loop?
    edited 2011-08-26 03:12
    Gyro is required with an accelerometer AFAIK, encoders are optional.
    Are you modeling your robot after someone else's? Tough project from scratch. I made a thread with lots of links to other balance bots: http://forums.parallax.com/showthread.php?126312-Balancing-Bot&highlight=balancing+bot Check out those references.
    edited 2011-08-26 07:36
    Yeah Ive read the Programing and Customizing the multicore Propellers section on Hannos Dance bot.It uses different parts but they are the same types.Also what Info that is available about example PID loops.What does AF AIK mean?The examples Ive read dont quiet match though they use heat and fans or IR distance to follow objects the PID principle is the same.The algorithms are not a good match though for a balance bot PID loop.So if I can get some help in the area of using the sensor values and Making the different equations for the PID loop as Ive done with the proportional section.Would be great.Currently It ramps up the motors proportional to the angle at which its falling.It needs more of the accumulative errors over time solved.Like OK im falling in one direction the motor starts to correct the issue but its not enough Im still falling same direction and by the time Id hit the ground the motors are full speed.Seems like a higher Mast (gettn the accellerometer higher up) would help this but its not the answer.
    edited 2011-08-26 08:04
    This snippet of code may work but It needs help there is the original un edited version also
    original
    ' PidMathExample.bs2
    ' Demonstrates how a combination of proportional, integral, and
    ' derivative control influence error correction in a feedback loop.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    SetPoint       CON     0                     ' Set point
    Kp             CON     10                    ' Proportionality constant
    Ki             CON     10                    ' Integral constant
    Kd             CON     10                    ' Derivative constant
    Current        CON     0                     ' Array index - current error
    Accumulator    CON     1                     ' Array index - accumulated error
    Previous       CON     2                     ' Array index - previous error
    Delta          CON     3                     ' Array index - change in error
    sensorInput    VAR     Word                  ' Sensor input variable
    error          VAR     Word(4)               ' Four different types of errors
    p              VAR     Word                  ' Proportional term
    i              VAR     Word                  ' Integral term
    d              VAR     Word                  ' Derivative term
    drive          VAR     Word                  ' Output
    DO
      DEBUG "Enter sensor input value: "
      DEBUGIN SDEC sensorInput
      ' Calculate error.
      error(Current) = SetPoint - sensorInput
      ' Calculate proportional term.
      p = Kp * error(current)
      ' Calculate integral term.
      error(Accumulator) = error(Accumulator) + error(Current)
      i = Ki * error(Accumulator)
      ' Calculate derivative term.
      error(Delta) = error(Current) - error(Previous)
      d = Kd * error(delta)
      ' Calculate output.
      drive = p + i + d
      ' Display values.
      DEBUG CR, CR, "ERROR", CR,
            SDEC ? SetPoint, SDEC ? sensorInput, SDEC ? error(Current), CR,
            "PROPORTIONAL", CR,
            SDEC ? Kp, SDEC ? error(Current), SDEC ? p, CR,
            "INTEGRAL", CR,
            SDEC ? Ki, SDEC ? error(accumulator), SDEC ? i, CR,
            "DERIVATIVE", CR,
            SDEC ? Kd, SDEC ? error(Delta), SDEC ? d, CR,
            "OUTPUT", CR,
            SDEC ? p, SDEC ? i, SDEC ? d, SDEC ? drive, CR, CR
      ' Save current error to previous error before next iteration.
      error(Previous) = error(Current)
    LOOP
    edited
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    SetPoint       CON     2538                     ' Set point
    Kp             CON     3                    ' Proportionality constant
    Ki             CON     1                    ' Integral constant
    Kd             CON     1                    ' Derivative constant
    DO
      PULSIN 6,1,sensorInput
      DEBUG CLS, ? sensorInput
      PAUSE 100
      ' Calculate error.
      p = Kp -88 * error(current)
      ' Calculate output.
      drive = p + i + d MIN 650 MAX 850
      ' Display values.
            "PROPORTIONAL", CR,
            "INTEGRAL", CR,
            "DERIVATIVE", CR,
            "OUTPUT", CR,
      PAUSE 100
      PULSOUT 15,drive
    LOOP
    edited 2011-08-28 05:54
    Ive noticed that the setpoint(point at which the bot balances) changes slightly.Ive seen a balance bot that when balanced by hand the operator pushes a button and manualy sets the set point.Any ideas?
    edited 2011-08-30 06:03
    In the example here http://forums.parallax.com/showthread.php?77656
    example two on integral
    you cant simply change Change the drive = i statement to drive = i + Offset MIN 650 MAX 850.
    √······· Run the program and verify that the integral output is limited to values between 650 and 850.· Try entering 2 repeatedly, then -2 repeatedly.
    Offset hasnt been declared.
    so offset = ?
    You cant use offset = ? either
    so i have
    drive = i + setpoint - current MIN 650 MAX 850
    is this correct?
    edited 2011-08-30 17:08
    Check out Ratronic's latest work with a ping & prop: http://forums.parallax.com/showthread.php?134189-Barely-balancing
    edited 2011-08-30 20:13
    latest portion of code debugs accelerometer,error,gyro,and drive values
    the drive value is a proportional acc. reading
    now Im looking to have the gyro feed the derivative portion of the PID loop?Oh boy...
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    tiltx           PIN     6
    hb25            PIN     15
    '---Variable----
    x              VAR       Word
    drive          VAR       Word
    error          VAR       Word(2)
    ' ---Constants---
    Kp          CON    3
    SetPoint    CON    2541
    Initialization:
      HIGH CSn
      LOW SCLK
      PAUSE 250
    '---Main---
    DO
      GOSUB Read_Gyro
          DEBUG "Gyro Reading:", DEC5 value
          PAUSE 100
      drive = x / Kp -97
      PULSIN 6,1,x
      PULSOUT 15, drive
      PAUSE 100
    LOOP
    Read_Gyro:
      LOW CSn
      HIGH CSn
      RETURN
    edited 2011-08-31 08:26
    Good progress! I know I'm restating the obvious when I say that the DEBUG statements are just for your observation of data gathered, and that you must comment them out to really test robot balance, as the comments will slow down program execution too much.
    Yours,
    Captain Obvious
    edited 2011-08-31 16:04
    Thanks erco.It had slipped my mind.I don't have a good grasp on the timing issues I'm certain to face.
    edited 2011-10-13 03:21
    I made some slight changes to my bot.I added a ping sensor to the bottom.Using only that the bot is balancing only slightly better,still very jerky.It stays upright though, probably a short amount of time.Again though no functional PID loop.
    edited 2011-10-13 20:07
    A Ping should work great, if your code works properly and your motors are fast enough. Here's my first reported success, using an IR sensor instead of Ping, and just Proportional control, not PID. Code is posted a few replies later.
    http://forums.parallax.com/showthread.php?126312-Balancing-Bot&p=965006&viewfull=1#post965006
  • danny_maertensdanny_maertens Posts: 1
    If anyone has a finished code i'd love to see it. Or if anyone can help me I am using the bs2, LISY300 Gyroscope module, and the MMA7455 3-axis accelerometer module. It's for a school project, it is an independent study and there is no teacher, so there is no one i can ask for for help. If you could spare some time it would be greatly appreciated. Thanks
