When I have more than one program open and press RUN, it runs the program in the first tab instead of the one in the current tab.
The xBasic IDE is setup to use a "project" scheme. If you want to build a file, you have to set it as the project.
Some files may use print which is included in the main project file. If you set that file to the project without including print.bas, you will get a compile error. According to David, you can include "print.bas" in files if you like, but only the first include "print.bas" in the files list will be used. Not sure what happens with the project/references list since i never tried that.
On the terminal window I clicked the help and mt mouse pointer stays the circle with the slash in it.
Now I get it ... sorry it took so long
The ? near the top right X-it button is not defined. I'll remove it.
Regarding BasicStamp PBASIC. The xBasic compiler does not understand PBASIC syntax.
It would take lots of motivation for David to consider supporting PBASIC syntax.
Appreciate the info on the term window, no need to remove the ? but could there possibly a clear screen button?
It also would be great for people like me who cut their teeth on a basic stamp to have a prop basic compiler that was pbasic :friendly: Any way I feel I will use this for my prop work. Also no problems with setting for the C3 in both hub ram and XMM. I am liking it alot!
I guess this is really for me since I did the language design and compiler. What pbasic features are you looking for? I haven't used pbasic myself so I'm not really familiar with its capabilities.
Also, isn't PropBasic similar to pbasic? Maybe you can use that if xbasic doesn't meet your needs.
Sorry jazzed, it is still not working. When I tried to create a simple program, the save part did not save the file. When I hit the build, it seem to accept that without error, but when I hit the run, it came up with a compile error. So, right now I can not get anything to run, it keeps coming up with a compiler error, other than that the program looks good. Can't wait to see BigSpin in action!
I guess what I would like is to be able to paste a Pbasic source code and get it to run with little muss or fuss. Probably not realistic. I have a program with ping and sensors to tell if someone or something is behind my power chair and set alarms for x and y axis tilt of the chair when I am roaming out side. (Grin). My wifes cat appreciates this as I accidentally ran over her tail once...
Sorry Bean but I never got to far with Prop Basic even though it seams to work also. For some reason unknown I couldn't get into it...
After the first RUN, all attempts after result in the "Lost HW contact" error.
Odd. I've tried this on 4 different board types except a QuickStart which I don't have.
Have you tried a different board? What is your PC O/S and CPU type?
Nice library code BTW. The functions would make a nice addition to the distribution.
I accidentally left a copy of your file in samples\bean.bas for the 0.1.6 distribution.
I have strange problems with Yours TV driver - It cut last 2-3 pixels on every line displayed.
I'm investigating this and will get back with it in a while.
Regarding "last folder" issue identified by JonnyMac: the open/save as dialog seems to remember the last folder in Windows 7 (unless the window is cancled). Windows XP uses that silly folder dialog thing and is quite annoying.
Ray, I suspect that your xbasic.cfg file in the include directory is corrupt. I had a backup mechanism at first but that caused more trouble than it was worth.
At this point, it's probably best to uninstall the program. I might try going back to a restore point - unfortunately the installer i'm using does not automatically create a restore point.
Reinstalling the new version may work but there is no guarantee. I've tested this on several machines and not any problem with the new version code. ...
Odd thing is that you said you could build but not run. Can you make a screenshot (Ctrl+PrtScr) of the error message box and post it? I get this if I don't have the right board-type:
BTW I stopped working on BigSpin mainly because of performance issues.
"accidentally" LOL. Thanks. I take that as a compliment. I'll build on it. I plan to expand the routines to handle multiple pins.
I've had times with my QuickStart boards that they have not reset reliably from the Propeller Tool when loading a new program. After a random and undocumented series of loads and reloads, it will work and be seen. I haven't tried xBasic yet (maybe tonight if I get to sit down a bit) but I can see if I can repeat the problem...and maybe come up with a repeatable solution. In all cases, the Quickstart has been USB powered and it has happened on at least 2 different computers.
I also have 32K and 64K quickstarts - I know I've seen the problem on the 64K boards.....not sure about the 32K boards. I of course was also playing with PropForth which I know invalidates my test results and has voided my warranty!
Attached is a zip that contains the 0.1.6 xbasic-qt.exe.
If you already have a working installation, drop the .exe into your
C:\Program Files (x86)\xBasic IDE\bin folder.
This would be faster than downloading a new package!
Sapieha, do you mean that NTSC works but PAL has the clipping problem?
If so, it's probably best if we make TVPAL.bas driver from an existing known good driver.
Doesn't Baggers have something that works for both? The driver I used was Chip's TV.spin.
Sorry, I have not yet integrated the tools for making these and other drivers.
1. Sapieha, do you mean that NTSC works but PAL has the clipping problem?
2. If so, it's probably best if we make TVPAL.bas driver from an existing known good driver.
Doesn't Baggers have something that works for both? The driver I used was Chip's TV.spin. 3. Sorry, I have not yet integrated the tools for making these and other drivers.
On 1. Yes - You are correct.
On 2. Any solution that will work are welcome.
On 3. I know You can't work on all at same time
@jazzed, it started to work, but I do not know why. The program is still a little finicky, for instance, when I have the testinput.bas loaded, and hit run, nothing seems to happen. I noticed on the propplug the little blue light is flashing, so something got loaded. When I hit debug, it opens, I guess, a terminal screen, but it just stays blank. Since the bas program contains some print statements, I was expecting something on the screen.
Well, at least it started run, will see what happens when I start it up tomorrow.
Ray it's probably working There is a delay between compile/download and terminal start-up.
Try this example.
include "input.bas"
include "print.bas"
include "propeller.bas" // add propeller specific code
dim a(32) as byte
waitcnt(clkfreq+cnt) // add 1 second delay
do
print "Type somethheing: ";
inputLine(0, a)
print "a='"; a; "'"
loop
I just noticed the little "*" keeps coming back on file tabs. Not sure why.
xBasic IDE installed and ran fine on my Acer Aspire One w/ 1GB running Windows 7Starter. The demos I tried worked fine with my 64kB Quickstart. I don't have any Prop boards with anything but HUB RAM so any testing I do will be limited to that memory model.
The look and feel of the IDE is impressive. I'm looking forward to doing more with it.
I noticed the same "loss of communication" issues with the QuickStart that Bean had mentioned. This is not limited to your IDE, I've seen this same problem with the Propeller Tool and the QuickStart board. If you unplug the USB cable and plug it in again, then the tools see the prop and can reload it. I need to gather my other USB connected cards and see if they have the same problem. I don't ever recall seeing this with a Prop Plug connected Prop. Further details is for another thread.
The IDE is looking good!! I haven't played enough to have any suggestions for additions.
I figured out what I was doing wrong to get that compiler error, if you have a mistake in the program like a missing '(' , or anything else, then the IDE produces a compiler error. It would be nice if the IDE would point out the reason for the compiler error. Now that I am of aware of that, the IDE seems to be behaving, although the program itself seems to freeze every once in awhile, to the point where I have use the task manager to kill it.
When you create a new file, and you hit the 'save', it does not save the new file, you have to use 'save as' on a new file, then 'save' for a save of changes to the file. It is not what I expected to happen, but I guess it is something one has to get used to.
I noticed in the propeller.bas, it contains a command for starting a new cog, any info as to what the proper usage would be? So far this program looks promising, I will have to dig out my C3 board, and see how it works with the extra SRAM, and flashram. This leads to another question, since the C3 board has an SD, is their a way to use it with xbasic?
There was a compiler change from V0.1.5 to V0.1.6 for error info. I didn't notice until yesterday after I posted an update. The next update will include error information again.
It would be very helpful if you can make notes of what you were doing before/during a freeze. I haven't seen any freezing.
There are some issues with save that I'm looking at today. I'll look at this too.
Look at the samples\TvDemo example. The include\TvText.bas shows how to start a COG. The cognew syntax is identical to Spin's cognew for PASM. You can not cognew an xBasic program.
There are few comments in propeller.bas and other includes - this needs some attention.
One of the file-system drivers needs to be ported to xBasic. Some silly C3 hardware decisions complicates things, but these can be overcome.
Oops! Sorry about that! I didn't make any intentional changes in the error code syntax. Maybe we should discuss this before you change anything. It might be my problem not yours!
The C3 cache driver used by xbasic already includes code for low level SD sector I/O. We just need the higher level code ported over. Unfortunately, that may be a big job.
Since the subject of SD is up, I also use the Gadget Gangster USB board which has an SD, will that be supported also? And how about the jazzed humungous RAM board, although I would like to see something replicates what the C3 has? Lets see, what other features does the C3 have, ADC, I think that is about it.
What program are you running? There was once a problem where board output would cause that error because the loader buffer wasn't flushed.
Thanks a ton for your help!
Ps. Look on posted pictures. Only thing that I changed are Row/Columns and from NCST to PAL
Will make some pics and post in this thread tomorow.
Here is the program
// Demo for QuickStart board include "propeller.bas" // waitcnt def inp(pin) dira=dira & ~(1 << pin) end def def out(pin) dira=dira | (1 << pin) end def def reverse(pin) dira=dira ^ (1 << pin) end def def high(pin) dira=dira | (1 << pin) outa=outa | (1 << pin) end def def low(pin) dira=dira | (1 << pin) outa=outa & ~(1 << pin) end def def toggle(pin) dira=dira | (1 << pin) outa=outa ^ (1 << pin) end def def pause(msec) waitcnt((clkfreq / 1000) * msec + cnt) end def // Main code do for i=16 to 23 toggle(i) pause(50) next i loopAfter the first RUN, all attempts after result in the "Lost HW contact" error.
P.S. The "changed" star after the filename does not go away when you save the file.
Bean
David
Ray
It includes fixes and enhancements identified in this thread.
Yes. Done.
Fixed in V0.1.6.
thanks
If You need I can post file I made changes in !
Please do. Thanks. I don't have a PAL TV but I'm sure others do and would appreciate it.
We still have lots of library code to write.
I can help You with all needed test's for PAL system.
file attached.
Bean
As You can see - problem are only on PAL side.
See pictures.
If you want to update your entire package, uninstall the old version first then install the with the new setup from: http://www.microcsource.com/xbasic/xBasicIDE.zip
Have You possibility to ADD in Properties one more Directory Input?
"Working Project Path"
That after start xBasic always starts in That Directory?
Try this example.
include "input.bas" include "print.bas" include "propeller.bas" // add propeller specific code dim a(32) as byte waitcnt(clkfreq+cnt) // add 1 second delay do print "Type somethheing: "; inputLine(0, a) print "a='"; a; "'" loopI just noticed the little "*" keeps coming back on file tabs. Not sure why.
Meanwhile, here is a procedure for converting any Spin PASM driver to xBasic.
The bin2xbasic.zip attached below contains bin2xbasic.exe for windows.
TV.spin is a good example to use. Any driver that uses a "mailbox" interface will work.
The QuickStart stuff is troubling. ... Especially if it's going viral....
I don't have a board so I can't experiment with it.
I have a USB ProtoBoard, C3, and other USB connected/powered devices.
They always work for me. All the PropPlug solutions work fine too.
Are there any theories at all as to why there might be an issue?
Ray
Glad to see you are having success with xBasic now
Thanks for your patience.
Ray
