Is there a way to send these 2 commands together?
I have these 2 lines:
Can they be combined somehow in one line to send both the $1_08 & $0_08 together? What is the syntax to do so?
Thanks.
Don
txmdbinv($1_08, MDB_MSTR) txmdbinv($0_08, MDB_MSTR)
Thanks.
Don
txmdbinv lives in the initial cog I believe. It is a pub method in my main object. In another program I have I am able to send these 2 "commands" I'll call them, with this line of code:
MDB_ACK = $00. MDB_SLAV is a pin.
I tried to do this in my code but it doesn't work: txmdbinv(($1_08) | $08, MDB_MSTR)
With this code:
I get this as an output:
Is there a way to combine both of those lines of code into 1?
Questions:
how many propeller-IO-pins do you use to transfer the commands?
What kind of interface is this SPI?, Serial?, I2C? something else?
please attach your complete code to a posting.
best regards
Stefan
It involves only 1 IO pin and it is serial. It isn't that important that it be condensed. I was just curious as I had seen it work in another program I have with similar conditions.
So what does this mean? Do you stop working on this?
keep the questions coming
best regards
Stefan
[b]pub[/b] txmdb_str(pntr) | cmd repeat cmd := long[pntr] if (cmd == -1) quit else txmdbinv(cmd, MDB_MSTR) pntr += 4 [b]dat[/b] Command1 long $1_08, $0_08, -1Pass the address of the command string you want to send:
