IR Compound Eye from RBB 4 and Let's Make Robots (Video)
RBB 4 and the Mr General Project from Let's Make Robots have information on this IR compound eye project:
http://letsmakerobots.com/node/10822
To use with a Basic Stamp 2 or Propeller you would need external A/D conversion, but that's a small thing. But two things about the schematic bug me because I don't understand them.
The 39 ohm resistors for the IR LED series/parallel array seem odd. I used this wizard http://led.linear1.org/led.wiz and it suggested two 100 ohm resistors for such an array. Using lower resistance will increase the brightness, so maybe that's desired to increase range.
The value of 820 ohms for the resistor on the transistor base also seems low. For similar circuits turning on an LED the values have been closer to 4.6 K ohm. Does the increased current draw from four IR LED's require the decreased value?
But 39 ohm and 820 ohm resistors aren't available locally, so I'm thinking of substituting. I could either go with a 100 ohm which the wizard suggested or use 33 ohms which is the closest value I've seen. Both of which I also already have. I also have some 1 K ohm resistors which measure a bit above 900 ohm, so I think one of them is close enough for the bias resistor.
When I tried the calculator I got 45 ohms. It all depends on the numbers you enter for drop and current.
You can only guestimate for the phototransistor resistors , as they'll really depend on the exact phototransistors you use. Unless you're designing for specific components it's all an approximation anyway. Your aim is to increase sensitivity while providing the highest voltage swing. Adjusting the resistance affects one or the other.
The only components you risk if you try a lower value is the IR LEDs. I wouldn't go much under 35 ohm, unless you're sure your LEDs support the current.
-- Gordon
Looks pretty for a point to point board! Just don't look on the back!
You'll also see the CBA with a propeller backpack and line scan camera on the Ping))) bracket. That's part of an unrelated project.
I formed the bracket and the beginnings of a tilt pan assembly out of sheet aluminum from the hardware store. I used my typical technique of marking a line, cutting with tin snips, and smoothing the edge with a file and sandpaper. A rubber mallet and a wooden mandrel were used to make the bracket shape. This time I am using mini-servos, so the assembly is quite small.
Between soldering the boards and making the bracket, my time investment greatly exceeded the cost of buying a kit from Robot shop. But I don't think I would have been as interested if I did that.
However, the robot chassis is a tank bot kit I bought from Servo Magazine, so this isn't a full scratch build.
You're even using one of my Tankbot Servo bots, so I'm doubly impressed. (I no longer make it, but if you need any replacement parts let me know. I still have the pattern files on my CNC.)
BTW, don't use the Tamiya track set with those higher power replacement FA-130 motors from Pololu. I used them on a different style of tracked robot, and they have so much torque they just strip out the plastic of the drive sprocket. I ended up having to clamp the sprocket to the hex shaft with a 1/4" collar and setscrew. Mad stuff.
-- Gordon
The genesis of this project is that my CBA robot is great for odometry and line following on hard smooth surfaces, but completely hopeless on uneven surfaces of any kind. So I started getting a yen for an all terrain robot. I was thinking of scratch building a 4WD like your Rigel design, but I saw that the TankBot kit was still available from Servo magazine. So I went with that instead.
I may still build a 4WD for outdoor use, but for the money required to build a good one a quadcopter might be the ultimate all terrain outdoor vehicle!
I am now programming and noticed that my right and top eye zones are far more sensitive than left and bottom. The DMM shows continuity for all phototransistor and equal values for all resistors. I measured voltage across the phototransistor and the values are slightly different for the more sensitive zones. So I can only assume the photo transistors are not well matched.
Any tricks to ensure more equal response?
Since you're dealing with proximate zones anyway, increase or decrease the returned values to equalize them. If it turns out they're not all linear (likely), and you need them to be, use a mapping function.
-- Gordon
-- Gordon
-- Gordon
For phase two I plan to add edge sensors so the tankbot won't drive off edges, as well as front and rear aluminum bumpers. I may circle back and build a second IR compound eye using higher quality phototransistors. The eBay specials I purchased are really non-linear in their response, so right versus left and up versus down are not equally responsive. I added scaling functions and some code to trim the last few bits, but it is still pretty twitchy.
Silly question: couldn't we do the same thing (with greater sensitivity & range) using four 38kHz IR detectors, looking for reflected 38kHz IR, in a multiplexed array?
Edit: In fact, there's a Scribbler or Boe-Bot app that does an IR frequency sweep to pseudo-measure distance, based on the 38 kHz detector's off-center sensitivity. I just know something like that could be used here. Simple hardware and clever coding could make that detect direction and distance in 2 axes, as the videos in the very first post showed.
Frankly the analog eye requires a fair bit of fiddling. You need to read the un-illuminated values, the illuminated values, and subtract the two. These delta must be zero adjusted and rescaled using measured constants in an attempt to make the response as linear as possible. But lighting condition and the phase of the Moon seem to change these constant values, so the result is a fairly twitchy robot. But that isn't all bad as the eye is dirt cheap, and the twitchiness adds randomness to the motion which could be handy in getting out of corners.
But all this means that multiple reads using a frequency sweep isn't all that much more trouble and you eliminate the need for analog to digital. Parallax designs using 38kHz IR detectors have a single center detector with an IR LED for each zone. Following that model you would have one or two IR LED's per zone and a single the 38kHz IR detector in the center.
This might be to reduce costs as a single 38kHz IR detector cost $4.00 at Radio Shack, so one per zone would get pricey. Would using the IR detectors in parallel increase sensitivity like a phototransistor or are they essentially digital and both would fire or neither?
I might just have to mess with this after we get back from vacation...
The primary aim of the compound eye is to use the patterns of on/off sensors to determine direction. Most line following algorithms work this way, converting the position of the line under an array to a number from 0 to n, with n/2 meaning the line is centered. A similar technique could be used for X and Y, converting on/off values for the left/right/top/bottom zones to any of nine directions. I suppose you could try to use a sensor like this to detect distance and not just close proximity, but I'm not sure it was really intended for that (other than a happy circumstance if it works).
The IRPD method using 38 kHz sensors can use one or two (or more) receivers; the wider the eye field, the more the separate sensors come in handy. For a sensor the size of the compound eye a single IR receiver in the center, with pulsed LEDs around it, should be sufficient. However, this still only gets you proximity. The receivers are digital on/off devices.
(Though for experimentation, Andy Lindsey's Boe text shows how to "sweep" the carrier frequency to roughly determine distance, since the further away from center frequency you get, the less sensitive the receiver becomes. IR using the strength of the reflecting beam is never an accurate measure of distance, since lots of things can effect how much light is bounced back.)
-- Gordon
I got the idea of measuring distances by reading OddBot's code. But he only estimated the distance by summing the value of all four channels, not a single channel.
Another interesting thing I've noticed is that the amount of illumination one sensor receives seems to alter the reading of the other sensors. For example if I add a light shield to one photo transistor, its reading goes down, but all the other sensors increase in value. So the channels seem some what coupled which is probably why OddBot did it that way.
Now I'm writing the code which will sweep through a range of frequencies for each zone and read the input state from the 38 KHz sensor. Obviously I want to do this as quickly as possible, but not so quickly that the readings blur together.
So I'm curious, how long after the trailing edge of the 38 KHz pulse will the detector stay high? I figure I need to wait that amount after the read and before the next pulse.
Update: I tried good old trial and error and have been able to do the frequency sweep for three zones. I can definitely sense five distance zones with a bit of jitter. The fourth zone seems to not work with the same time constant. Not sure what is up with that.
Thanks, that makes sense. Unfortunately I don't have a scope, and could use one for this project. Hopefully I'll have time for a video this weekend after ironing out the remaining kinks.
The detector goes active low, but you knew that!
With some work, you could get tricky and use PULSIN to measure the active low period. You could start PULSIN with the IR output signal the IR signal seperately (no delay), then AND/OR that with the delayed IR sensor output.
Do remember that you should provide a stream of pulses with a "quiet" time between. Most of the datasheets for these things show this. The off period aids the detector in setting a quiescent level. The AGC inside the detector may not function properly if you constantly bombard it with a signal, and range could be affected. A good rule of thumb is 600 us or longer on, then off, then on, then off, etc. If you're pulsing four LEDs, you want the quiet period between each of the four. Avoid pulsing them right after the other, as the detector could see this as a steady stream.
-- Gordon
Gordon, thanks this is good information.
The detector came from Radio Shack with only the pin out diagram. The Radio Shack website has no pointers to data sheets. The part number looked like a radio Shack catalog number and not an industry one. Things are mostly working, but I definitely need to shorten my pulses and increase the quiet time between pulses.
My concern was two fold. One was waiting two long after the pulse to read the input, but that hasn't been a problem. The second part was what you described which was not giving the detector enough down time. I think that might be the case and I need to tweak my code.
Erco, using the microcontroller as the calibration tool is a good idea and I'll try that too.
A duration of one millisecond on, one millisecond off, is a convenient rounded-up duration most MCUs are capable of. A couple of milliseconds on and off probably won't upset its AGC. More than a half-second or a second...might be pushing it. (But I also imagine this will largely depend on the specific device.)
Even if there is a 50% latency in the output, with respect to the input burst, you shouldn't have a problem detecting it. I don't recall what controller you're using, but a typical method is to drive the 38 kHz pulses from a timer connected to one end of the LED (or use a 555 or something), then gate the LED on and off from another pin. You can play to see if you need any slight delays after gating the LED, and before testing the output of the receiver.
-- Gordon
