USB To Serial cable not working..... BS2 — Parallax Forums
mdenismdmdenismd Posts: 8
edited 2011-08-16 17:16 in BASIC Stamp
Hi, Has anyone been sucessful in using a USB to Serial cable on a BS2 running Windows7? I've tried many diffrent drivers... Trying to jump back into the programing after a long vacation and hit with this challenge first!!! Thanks
    edited 2011-08-15 14:53
    Yep, and it all depends on your cable. Not all work.
    Whaddaya got?
  • mdenismdmdenismd Posts: 8
    edited 2011-08-15 17:21
    Thanks.. It must be a generic one. No name on the boots (blue) with silver cable. I beleve this worked on my old XP system with the stamp2. broke the boot apart, board is marked USB-MAX211_led chip is the Max 211, no surprise, and the Au9720. IM READY TO JUST PURCHASE A KNOWN WORKING UNIT.....
    edited 2011-08-15 18:06
    Yes, the advantage of buying Parallax equipment is that you know it's spec'd to work right.
    [Follow the installation notes, etc.]
  • hmillerhmiller Posts: 17
    edited 2011-08-16 08:09
    I have a blue adapter with silver cable, the driver I use is called a prolific pl203 driver. It works with windows 7 and xp
    edited 2011-08-16 09:12
    Prolly a pl2303...
    edited 2011-08-16 15:58
    woops I missed a 3 lol
    Did it ever work on another OS, another computer? If not, you may have a cheapie with inverted signals. Check this thread http://forums.parallax.com/showthread.php?133195-USB-Adapter-Fix&highlight=usb+serial+adapter if you like to experiment, you might be able to make an adapter that works using a 50-cent inverter.
