Ping Interference Issue
Any ideas what might be triggering a Ping sensor in an office environment? I am using the sensor in what is functionally equivalent to a Boe-Bot. At work, the ping sensor triggers as if there is an object a short distance away amost immediately upon activation.
Standard office - Cubes, flourescent lights, computers, printers, etc.
Dave
Any help would be appreciated. If nothing occurs to you, I will post the code over the weekend. Thanks!
Otherwise, I think it's as Erco says...your bot just doesn't want to be at work.
-- Gordon
