What to Do with Your Robot Arm
Stack wooden robots, of course! http://www.amazon.com/Schylling-WSR-Wood-Stacking-Robots/dp/B000ELQVAI/ref=sr_1_1?ie=UTF8&qid=1312219178&sr=8-1
Towers of Hanoi has been done to death (Martin_H at least virtually, any progress there?) so it's time to move on to something more challenging and fitting. EVERYONE loves wooden robots, so get out those arms and start programming!
Besides getting side tracked, I concluded that I needed to create a fixed work surface for the arm to keep everything aligned. So I have a bit of construction to do also.
Tony
Thattaboy! Arms are very cool and can be simple or complex. Here's my first, a single weekend project: http://www.youtube.com/watch?v=-Z8lTSX4PHs
... and I just ordered ten of these grippers: http://www.solarbotics.com/products/50855 I have big plans!
I saw that Solarbotics' gripper - pretty cool and a good deal too. At 10 you got the discount and the free shipping - Clever boy!
At the moment it's not a time issue. Projects have the fun part and the slog part. My Hanoi project entered the slog phase and I found another fun project. But a wooden robot arm stacking wooden robots may shame me into finishing.
@Whit: EXACTLY! I may have a few extras, but you know how I love a good bulk discount, no tax & free shipping.
@Humanoido: You DO recall my Doc Oc post, and I HAVE been working on them. You'll see!
Just in case anybody else is ordering a gripper, avoid the wait and order a servo too!
Sparkfun sells the gripper and this "medium" servo http://www.sparkfun.com/products/10333
How much would you say the gripper weighs?
@Tony: 65.3 grams without servo or any mounting hardware. A tad heavy, but nice. The servo will strip gears long before this thing yields.
Edit: You could drop a few grams of weight by removing two small mounting flanges and the pair of nuts/bolts holding them on, if you can use the 2 resulting holes in the main plate to attach to. Visible in the pic at http://www.sparkfun.com/products/10332
The weight seems a little high to me as well. I'm really trying to watch the weight. Don't want the servos having to use most of their power just to lift itself.
@Tony: I hear you, and your concerns are valid and justified. I've seen more than one robot arm built that could barely move itself, and had virtually no payload lift capacity. Suitable for weightless ISS operation only! Countersprings at each joint make sense in a case like this, to negate the weight of the arm itself. Maybe even over-springing, so the the unloaded arm needs to work some to lower towards the ground, in order to increase payload capacity.
Here is one I made mostly from wood about 2 years ago.
http://diyrobots.webng.com/VideoP/VideoP.htm
http://www.budgetrobotics.com/shop/?cat=159
SHAMELESS, I know. But I couldn't resist! I designed it for myself, then decided may others would find it practical.
Yeah, it's more than the others, but it'll actually lift and hold something. I usually put drip irrigation rubber tubing over the fingers for extra grip.
Anywho, I know the guys who designed and sell the cast aluminum gripper that Solarbotics and Sparkfun offers. I got one in to test and wasn't too happy with the mechanism, but it IS inexpensive. Like Erco sez, it's not too hard to adjust the nuts and screws for a better fit. Nylon locking nuts always need a bit of finesse.
The Sparkfun/Solarbotics/Robotshop claw ("That's CRAW, not craw!") likely was designed for either a GWS Mini servo (the one I used, which fit perfectly), or an HXT.
-- Gordon
This is where a good local hardware store comes in handy. Home Depot and Lowe's just don't cut it. I went in to my local Tru Value, asked to see their spring drawer, and hand tested a bunch of 'em. I came away with five or six contenders, and tried several that will work.
Yes to over-springing. Along with the lilies of the field, consider the lowly garage door (the old kind, not the newfangled rollup).
-- Gordon
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250773594217
I've been trying to figure out how to get it to lift cuvettes (small test tubes) from a rack, place them in a spectrometer and then return the cuvettes to the rack. I'm realizing this is going to be no small task.
The guy who just replaced the huge springs in our newfangled rollup garage door told me the the springs do most of the work. The motor isn't strong enough to lift the door without the springs.
I think springs could really help the AX-12 arm. Heck even rubber bands might be helpful (and probably quieter).
Duane
I'm still trying to come up with a good gripper design that doesn't weigh a ton, is steady, and I know the orientation of the robots in the gripper. This is a great challenge and I love it! I've had to rest on this project a while as I finish up work before harvest starts next week. Progress may be slow the next two months but be assured I'll be working on it every chance I can.
As for the nested robots I thank that might just be a great use for the soft gripper made from coffee and a latex balloon. But again, known orientation of the pieces in the gripper is a big issue.
Tony
http://www.youtube.com/watch?v=Qcw1CEbeV-o
I'm guessing there's a swap meet element to the Expo. I'll also bring some things for the freebie table.
