Counter, Cogs, Methods and Objects. What runs In what Cog?
Say for example COG 0's first method launches another COG's Counters using cognew to do something, the counters are counting away and the COG is free to do other stuff this is COG 1. Then COG 0 launches another COG using cognew to do something run a method or object not involving Counters. Will the code be launched in COG 1 or does it get passed to COG 2? If the method or object used the counters what would happen?
Confused Ron
Confused Ron
This is what confused me the comments in the SecondProcess Method. So if the counters where running for say a Minute that Cog's processor I guess would be unavailable for that time. The code is from PE Kit Tools. The comments make it sound like the Cog is ready for work.
VAR long stack[50] ' Stack for SecondProcess OBJ sqw : "SquareWave" ' Declare Square wave object PUB go 'clkgen.Freq(I/O pin, module=0 or 1, frequency in Hz) sqw.Freq(4, 0, 10) ' P4, channel 0, 10 Hz sqw.Freq(5, 1, 25) ' P9, channel 1, 25 Hz 'Cog moves on to other jobs and lets counter modules blink the lights. waitcnt(clkfreq*3+cnt) ' Blink for 10 seconds cognew(SecondProcess, @stack) ' Launch another cog waitcnt(clkfreq*2+cnt) ' 4 square waves, 2 more seconds sqw.FreqUpdate(0,5) ' Channel 0 freq to 5 Hz waitcnt(clkfreq*2+cnt) ' 4 square waves, 2 more seconds sqw.End(0) ' End Channel 0 transmission sqw.End(1) ' End Channel 1 transmission PUB SecondProcess ' This second cog uses the same square wave object to configure its counter ' modules to create two more square waves. As with the other cog, this cog's ' does not need to do anything to keep the square waves going, so it can move ' on to other tasks. sqw.Freq(6, 0, 11) ' P6, channel 0, 17 Hz sqw.Freq(7, 1, 23) ' P7, channel 1, 25 Hz waitcnt(clkfreq*5+cnt) ' Send for about 5 seconds sqw.End(0) ' End Channel 0 transmission sqw.End(1) ' End Channel 1 transmissionRon
In the example you posted it just waits because it doesn't have anything useful to do. It's your choice in the end.
Thanks again Ron
