Any ideas on scaled Font smoothing
Peter Jakacki
Hi everyone, I know I've been really quiet on the forum lately, haven't really had much of a chance to lurk either :frown:
Anyway, I'm not sure if I'm reinventing the wheel here but I wanted scaled VGA characters so I got stuck into some PASM tonight and although I'm really rusty I managed to get the basics of scaling the Prop font onto a VGA monitor. So far so good....
What I'd like to do is smooth the font especially when it's scaled up. Any ideas (any code) anyone?
Cheers,
Peter
Cheers,
Peter
a small scanning algorithm could do these fillings
I'm looking at a pixel by pixel smoothing during rendering as this is a bit-mapped display and I am drawing the scaled characters straight from the Prop's ROM. I was thinking of an algorithm that worked a bit like molasses in that the stickiness of it would be determined by the scaling factor. You with me so far??? A bit like we smooth out waveforms with capacitors.
If there is a lookahead to what the next non-repeat row of pixels are then we can (depending upon the scaling factor of course) make gradual adjustments in each repeat row of the old data.
Take is un-smoothed sample for instance:
**** **** **** **** ******** ******** ******** ******** **** **** **** **** ******** ******** ******** ******** Adding pixels (#) and subtracting pixels (.) to approach the next non-repeat row (every 4th here) will smooth out the shape. **** #**** ##**** ###**** ******** *******. ******.. *****... **** ****# ****## ****### ******** ******** ******** ******** So we end up with: **** ***** ****** ******* ******** ******* ****** ***** **** ***** ****** ******* ******** ******** ******** ********Okay, I'm probably talking more than doing at the moment but I did ask. I will have to try this out on the same display and compare the difference.
