XBee Learning Curve
ajward
Hey All...
Got the XBees assembled this afternoon with a few glitches... on my end.
First of plugged the USB adapter into the peecee and nothing! Checked the cable - okay! Re-check my soldering - Looked okay! FTDI drivers - Seem to be there! Swapped XBee module - Nothing!
Hmm... switched USB ports on the peecee -> Shazam! There be lights.
Next... no communication between modules. Swapped modules - nothing! Checked the wiring on the H/W board and I missed the VSS pin on the adapter... Ah... now there are lights on the board. Still no communication.
Wait... the LEDs on the remote board are nowhere near as bright as on the USB board. Swapped 9V batteries and we be working!!!
All the tests in the XBee manual have worked so far... just transmitting to a module in loopback mode, but this is seriously cool! Put the remote 'Bee in a far corner of the apartment and was getting 100% in the range test.
Amanda
Amanda
-Martin Hebel
Up and running, I was able to send data both ways. From the netbook in the living room to the peecee in the bedroom. My roomie thought it was pretty cool too!
Experimentation is done for the evening.
Amanda
