Parallax Balance Bot
I may be a little wrong on some things.
I have a Us Digital rotory encoder from LynxMotion QME-01
Im using a BS2 MCU.
Memsic 2125 accelerometer
Lisy300 gyro
HB25 motor controllers
Currently all the parts arent being used.I tried creating different code for each at different times with no sucsess.
post # 9 is probably the most functional example of proportional
When power is applied to the motor Im gettn a reading but when the motor stops the encoder resets back to zero.
I'd like to keep the variable from reseting back to zero?
This is part of a balance bot project.I have parts of code and changes made to the original design ie.I switched out the LMD 18200 H bridges for HB25 motor controllers
.I need help compiling it all together.Possiblily with a PID loop.
here are more bits of code that need adjustment.
Im out of time for now (off to work) I know its messed
here is sample PID loop info any help I can get with setting scales and algorithms would be excellent!!!
http://forums.parallax.com/showthread.php?77656
Im using a BS2 MCU.
Lisy300 gyro
' {$STAMP BS2}
' {$PBASIC 2.5}
' HomeBrew-Gyro-Tilt-levellights-encoder-debug.bs2
' Measure room temperature tilt,and give gyro reading in x plane.level indicator lights.
' -----[ I/O Definitions ]-------------------------------------------------
Dout PIN 0 ' P0 <-- Dout (LISY300.2)
SCLK PIN 1 ' P1 --> SCLK (LISY300.4)
CSn PIN 2 ' P2 --> /CS (LISY300.5)
tiltx PIN 6 ' memsic 2125 X axis
tilty PIN 7 ' memsic 2125 Y axis
encoderA PIN 9 'Lynx Motion motor encoder QME-01
encoderB PIN 8 'Lynx Motion motor encoder QME-01
BiColorledGREEN PIN 13 ' x axis down light led green when high and low 12
BiColorledRED PIN 12 ' x axis up light led red when high and low 13
' -----[ Constants ]-------------------------------------------------------
Yes CON 1 ' Yes Constant
No CON 0 ' No Constant
' -----[ Variables ]-------------------------------------------------------
value VAR Word ' ADC Result Value
x VAR Word
y VAR Word
a VAR Word
b VAR Word
' -----[ EEPROM Data ]-----------------------------------------------------
' -----[ Initialization ]--------------------------------------------------
Initialization:
HIGH CSn
LOW SCLK
PAUSE 250
' -----[ Program Code ]----------------------------------------------------
Main:
DO
GOSUB Read_Gyro
DEBUG "ADC Value:", DEC5 value
PAUSE 250
PULSIN 9, 1, a
PULSIN 8, 1, b
PULSIN 6, 1, x
PULSIN 7, 1, y
IF x > 2525 THEN HIGH 13: LOW 12 ' x axis down light led 1 green
IF x < 2525 THEN LOW 13: HIGH 12 ' x axis up light led 2 red
IF x = 2525 THEN PAUSE 250
DEBUG CLS, ? X, ? Y, ? a, ? b
PAUSE 100
LOOP
STOP
' -----[ Subroutines ]-----------------------------------------------------
Read_Gyro:
LOW CSn
SHIFTIN Dout, SCLK, MSBPOST, [value\13]
HIGH CSn
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
' HomeBrew-Gyro-Tilt-motor-encoder-debug.bs2
tiltx PIN 6
tilty PIN 7
encoderA PIN 9
encoderB PIN 8
motorpowr PIN 15 ' motor power
motorDir PIN 14 ' motor direction
x VAR Word
y VAR Word
a VAR Word
b VAR Word
Initialization:
HIGH CSn
LOW SCLK
PAUSE 250
Main:
DO
GOSUB Read_Gyro
PAUSE 10
HIGH 15
PAUSE 100
LOW 15
PAUSE 150
PULSIN 9, 1, a
PULSIN 8, 1, b
PULSIN 6, 1, x
PULSIN 7, 1, y
IF x > 2525 THEN HIGH 14
IF x < 2525 THEN LOW 14
PAUSE 10
LOOP
STOP
Read_Gyro:
LOW CSn
HIGH CSn
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' This program tests the HB-25 by waiting for it to power up, then pulsing
' the output to ramp the motors up in opposite directions, wait 3 seconds
' then ramp them back down to a stopped position. While the code is
' written for two HB-25/motors you can use it with just one by commenting
' out or removing the lines for the second motor, commented below. If you
' have two HB-25/motors connected, remember to remove the jumper block from
' the second HB-25.
HB25 PIN 15 ' I/O Pin For HB-25
index VAR Word ' Counter For Ramping
x VAR Word
y VAR Word
a VAR Word
b VAR Word
DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up
LOW HB25 ' Make I/O Pin Output/Low
PAUSE 5 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750 ' Stop Motor 1
PAUSE 1 ' 1 mS Delay
PULSOUT HB25, 750 ' Stop Motor 2 (If Connected)
' The Above 2 Lines May Be Removed
' If You Are Using Single Mode
Main:
DO
PAUSE 20 ' Wait 20 mS Before Ramping
PULSIN 9, 1, a
PULSIN 8, 1, b
PULSIN 6, 1, x
PULSIN 7, 1, y
FOR index = 0 TO 250 ' Ramp Up To Full Speed
PULSOUT HB25, 750 + index ' Motor 1 Forward
PAUSE 1 ' 1 mS Delay For Motor 2 Pulse
PULSOUT HB25, 750 - index ' Motor 2 Reverse
PAUSE 20 ' 20 mS Smoothing Delay
NEXT
PAUSE 3000 ' Wait 3 Seconds
FOR index = 250 TO 0 ' Ramp Back Down
PULSOUT HB25, 750 + index ' Motor 1 Forward Slowing
PULSOUT HB25, 750 - index ' Motor 2 Reverse Slowing
NEXT
LOOP
PULSIN measures the width of an incoming pulse train and therefore can measure speed (or some other value) by watching the width of the pulses coming in. BUT, if the pulses are too far apart or too large (like when the shaft has stopped, they go to zero). Trying to store the value in EEPROM will not help. As well, if the pulses get too fast, there comes a point the Stamp can't process the value. More detail is available in the Helpfile.
Cheers,
I wanna see your balance bot in action, a subject near & dear to my heart!
' {$STAMP BS2} ' {$PBASIC 2.5} ' HomeBrew-Gyro-Tilt-motor-encoder-debug.bs2 ' Measure room temperature tilt,and give gyro reading in x plane. ' -----[ I/O Definitions ]------------------------------------------------- Dout PIN 0 ' P0 <-- Dout (LISY300.2) SCLK PIN 1 ' P1 --> SCLK (LISY300.4) CSn PIN 2 ' P2 --> /CS (LISY300.5) tiltx PIN 6 tilty PIN 7 encoderA PIN 9 encoderB PIN 8 HB25 PIN 15 ' motor power bicolorledgreen PIN 12 ' motor direction bicolorledred PIN 13 ' -----[ Constants ]------------------------------------------------------- Yes CON 1 ' Yes Constant No CON 0 ' No Constant ' -----[ Variables ]------------------------------------------------------- value VAR Word ' ADC Result Value x VAR Word y VAR Word a VAR Word b VAR Word index VAR Word ' Counter For Ramping ' -----[ EEPROM Data ]----------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- Initialization: HIGH CSn LOW SCLK PAUSE 250 ' -----[ Program Code ]---------------------------------------------------- Main: DO GOSUB Read_Gyro DEBUG "ADC Value:", DEC5 value PAUSE 10 LOW 15 PAUSE 5 PULSIN 9, 1, a PULSIN 8, 1, b PULSIN 6, 1, x PULSIN 7, 1, y IF x > 2525 THEN PULSOUT 15,650 : HIGH 12 : LOW 13 IF x < 2525 THEN PULSOUT 15,850 : HIGH 13 : LOW 12 IF x = 2525 THEN PAUSE 250 DEBUG CLS, ? X, ? Y, ? a, ? b PAUSE 10 LOOP STOP ' -----[ Subroutines ]----------------------------------------------------- Read_Gyro: LOW CSn SHIFTIN Dout, SCLK, MSBPOST, [value\13] HIGH CSn RETURNhttp://36ohk6dgmcd1n.yom.mail.yahoo.net/om/api/1.0/openmail.app.invoke/36ohk6dgmcd1n/4/1.0.35/us/en-US/view.html#
http://forums.parallax.com/showthread.php?121179-Reading-Quadrature-Encoders
in tryn to use this code with a added DEBUG line im getting errors
' {$stamp bs2} ' Program to act as high speed quadrature counter ' Program Name: quadhicount.bs2 ' Last Update: Mar 10/01 tjs DIRH=%11111111 counter VAR Word counter2 VAR Word counter3 VAR Word old VAR Nib new VAR Nib direct VAR Byte ' Channel a and b of encoder go on inputs 4 and 5 in this case. quad: counter=127 'load a dummy value so can count up or down new = INB & %0011 ' get initial condition start: old = new & %0011 ' remember initial setting again: new = INB & %0011 ' get new reading IF new=old THEN again direct=new.BIT1 ^ old.BIT0 ' XOR left bit of new with right bit of old to get direction IF direct=1 THEN cw ' jump here to increment LOW 0 ' pin 0 turns led off id turning counter-clockwise counter=counter-1 ' jump here to decrement OUTH=counter.LOWBYTE DEBUG HOME, DEC3 counter GOTO start cw: HIGH 0 ' pin 0 turns on led if turning clockwise counter=counter+1 OUTH=counter.LOWBYTE 'turn on leds on pins 8 through 15 to watch count GOTO start2515 is level divide that by 3.35 it gives me about 750 which is used to control the motor.
as is,it seems to work right but only as if like 2250 were level
' {$STAMP BS2} ' {$PBASIC 2.5} tiltx PIN 6 hb25 PIN 15 '---Variable---- x VAR Word ' ---Constants--- Kp CON 3 SetPoint CON 2515 '---Main--- DO PULSIN 6,1,x DEBUG CLS, ? X, ? 15 PULSOUT 15, x / Kp PAUSE 100 LOOPI added - 93 and it works more at level but LOL its goes the opposite direction any suggestions?fixed
also added a drive variable that displays the pulsout value used to drive the motors and debug setpoint,error,and drive values
' {$STAMP BS2} ' {$PBASIC 2.5} tiltx PIN 6 hb25 PIN 15 '---Variable---- x VAR Word drive VAR Word error VAR Word(2) ' ---Constants--- Kp CON 3 SetPoint CON 2543 '---Main--- DO drive = x / Kp -93 error = x - setpoint PULSIN 6,1,x DEBUG CLS, ? setpoint, ? X, ? error, ? drive PULSOUT 15, drive PAUSE 100 LOOPAre you modeling your robot after someone else's? Tough project from scratch. I made a thread with lots of links to other balance bots: http://forums.parallax.com/showthread.php?126312-Balancing-Bot&highlight=balancing+bot Check out those references.
original
' PidMathExample.bs2 ' Demonstrates how a combination of proportional, integral, and ' derivative control influence error correction in a feedback loop. ' {$STAMP BS2} ' {$PBASIC 2.5} SetPoint CON 0 ' Set point Kp CON 10 ' Proportionality constant Ki CON 10 ' Integral constant Kd CON 10 ' Derivative constant Current CON 0 ' Array index - current error Accumulator CON 1 ' Array index - accumulated error Previous CON 2 ' Array index - previous error Delta CON 3 ' Array index - change in error sensorInput VAR Word ' Sensor input variable error VAR Word(4) ' Four different types of errors p VAR Word ' Proportional term i VAR Word ' Integral term d VAR Word ' Derivative term drive VAR Word ' Output DO DEBUG "Enter sensor input value: " DEBUGIN SDEC sensorInput ' Calculate error. error(Current) = SetPoint - sensorInput ' Calculate proportional term. p = Kp * error(current) ' Calculate integral term. error(Accumulator) = error(Accumulator) + error(Current) i = Ki * error(Accumulator) ' Calculate derivative term. error(Delta) = error(Current) - error(Previous) d = Kd * error(delta) ' Calculate output. drive = p + i + d ' Display values. DEBUG CR, CR, "ERROR", CR, SDEC ? SetPoint, SDEC ? sensorInput, SDEC ? error(Current), CR, "PROPORTIONAL", CR, SDEC ? Kp, SDEC ? error(Current), SDEC ? p, CR, "INTEGRAL", CR, SDEC ? Ki, SDEC ? error(accumulator), SDEC ? i, CR, "DERIVATIVE", CR, SDEC ? Kd, SDEC ? error(Delta), SDEC ? d, CR, "OUTPUT", CR, SDEC ? p, SDEC ? i, SDEC ? d, SDEC ? drive, CR, CR ' Save current error to previous error before next iteration. error(Previous) = error(Current) LOOPedited' PidMathExample.bs2 ' Demonstrates how a combination of proportional, integral, and ' derivative control influence error correction in a feedback loop. ' {$STAMP BS2} ' {$PBASIC 2.5} SetPoint CON 2538 ' Set point Kp CON 3 ' Proportionality constant Ki CON 1 ' Integral constant Kd CON 1 ' Derivative constant Current CON 0 ' Array index - current error Accumulator CON 1 ' Array index - accumulated error Previous CON 2 ' Array index - previous error Delta CON 3 ' Array index - change in error sensorInput VAR Word ' Sensor input variable error VAR Word(4) ' Four different types of errors p VAR Word ' Proportional term i VAR Word ' Integral term d VAR Word ' Derivative term drive VAR Word ' Output DO PULSIN 6,1,sensorInput DEBUG CLS, ? sensorInput PAUSE 100 ' Calculate error. error(Current) = SetPoint - sensorInput ' Calculate proportional term. p = Kp -88 * error(current) ' Calculate integral term. error(Accumulator) = error(Accumulator) + error(Current) i = Ki * error(Accumulator) ' Calculate derivative term. error(Delta) = error(Current) - error(Previous) d = Kd * error(delta) ' Calculate output. drive = p + i + d MIN 650 MAX 850 ' Display values. DEBUG CR, CR, "ERROR", CR, SDEC ? SetPoint, SDEC ? sensorInput, SDEC ? error(Current), CR, "PROPORTIONAL", CR, SDEC ? Kp, SDEC ? error(Current), SDEC ? p, CR, "INTEGRAL", CR, SDEC ? Ki, SDEC ? error(accumulator), SDEC ? i, CR, "DERIVATIVE", CR, SDEC ? Kd, SDEC ? error(Delta), SDEC ? d, CR, "OUTPUT", CR, SDEC ? p, SDEC ? i, SDEC ? d, SDEC ? drive, CR, CR PAUSE 100 PULSOUT 15,drive ' Save current error to previous error before next iteration. error(Previous) = error(Current) LOOPexample two on integral
you cant simply change Change the drive = i statement to drive = i + Offset MIN 650 MAX 850.
√······· Run the program and verify that the integral output is limited to values between 650 and 850.· Try entering 2 repeatedly, then -2 repeatedly.
Offset hasnt been declared.
so offset = ?
You cant use offset = ? either
so i have
drive = i + setpoint - current MIN 650 MAX 850
is this correct?
the drive value is a proportional acc. reading
now Im looking to have the gyro feed the derivative portion of the PID loop?Oh boy...
' {$STAMP BS2} ' {$PBASIC 2.5} Dout PIN 0 ' P0 <-- Dout (LISY300.2) SCLK PIN 1 ' P1 --> SCLK (LISY300.4) CSn PIN 2 ' P2 --> /CS (LISY300.5) tiltx PIN 6 hb25 PIN 15 '---Variable---- x VAR Word drive VAR Word error VAR Word(2) value VAR Word ' ADC Result Value ' ---Constants--- Kp CON 3 SetPoint CON 2541 ' -----[ Initialization ]-------------------------------------------------- Initialization: HIGH CSn LOW SCLK PAUSE 250 '---Main--- DO GOSUB Read_Gyro DEBUG "Gyro Reading:", DEC5 value PAUSE 100 drive = x / Kp -97 error = x - setpoint PULSIN 6,1,x DEBUG CLS, ? setpoint, ? X, ? error, ? drive PULSOUT 15, drive PAUSE 100 LOOP ' -----[ Subroutines ]----------------------------------------------------- Read_Gyro: LOW CSn SHIFTIN Dout, SCLK, MSBPOST, [value\13] HIGH CSn RETURNYours,
Captain Obvious
http://forums.parallax.com/showthread.php?126312-Balancing-Bot&p=965006&viewfull=1#post965006
