BS2 Componentry Question
So .... what is the yellow component (circled) on the BS2 board and where can I get one.
I had a little power supply issue (okay, large issue), and blew it off the board. I know the BS2 may be smoked otherwise but I want to try and replace this component before tossing the BS2 into the garbage can.
Brian
Brian
If you're unconfortable about it popping again, you can go with Aluminum Polymer SMD capacitor with same rating, maybe half the uF rating - Tantalum capacitors fail by going off with a bang (after going short-circuit internally).
Brian D, at least you would have couple BS2 to cannibalize to replace what's smoked.
Have a happy tinkering day!
Welcome to the Forums!
We have piles of those caps - PM me with your mailing address :-)
(or you can go with WBA's offer - or both!)
-Matt
That said, take up Andrew on his generous offer. Assuming you can solder SMT components, perhaps your Stamp can organ donor a few parts to get one of HIS Stamps going!
