WAV File Magic - Page 2 — Parallax Forums
WAV File Magic
2»
  • KyeKye Posts: 2,200
    edited 2011-07-20 13:53
    Okay, here's another version. This will be the final. I added code to allow you to more easily track the wav file. Also, I strictly say this thing will work perfectly for audio files well over 1 second of audio and well under 2GB of data. Beyond those limits and the realities of mathematics and device speed come into play. Enjoy!
  • MacTuxLinMacTuxLin Posts: 821
    edited 2011-08-03 08:56
    JonnyMac wrote: »
    Chip did this for me with his StereoDuty object -- which is really quite simple once done (I use this in the AP-16+). Instead of writing your volume-adjusted samples to the counter/DACs, you reconstruct a 32-bit word and write it to the hub to be picked up by StereoDuty. This takes care of adding white noise to the sample that is removed by the DAC's RC circuit.
    Hi Jon,
    Is this "StereoDuty" object available for download? Don't see it on OBEX.
  • JonnyMacJonnyMac Posts: 9,839
    edited 2011-08-03 09:18
    It's attached to more than a couple demos I've posted.
    its in the propeller tool library.
    edited 2011-08-03 09:30
    Thank you Jon & Kye.
  • gr8_big_geekgr8_big_geek Posts: 34
    edited 2011-08-25 01:59
    Kye,
    Thank you for posting your .zip doc with the programs/coding to play a .wav file. I've been looking for something just like this!
    I have a few questions though. Which "demo board" would I need? The Propeller Demo Board? Would you recommend the Propeller Starter Kit?
    I have a post here where I'm asking the best way to play a .wav or .mp3 player. I'm trying to develop a keypad that will lock/unlock a cabinet. At the same time, I'm trying to get this keypad to play audio sounds to me in my office if the kids are attempting to unlock this cabinet. In a way, I'm trying to get this keypad to act like a doorbell/door lock. If I type the correct combination of keys then it should unlock the cabinet; however, if I do not then it will play the incorrect password .wav/.mp3 file.
    Any feedback/suggestions would be wonderfully helpful. I'm currently trying to get the "shopping list" of items together that I would need to purchase to get this all together. Also, any programming I may need to learn in order to pull this all off.
    Thanks in advance!
    edited 2011-08-26 13:23
    Yeah, the propeller demo board is all you need to use the software. It's as simple as it can get. Use the lastest driver here: http://obex.parallax.com/objects/567/
    Then just use the matric keypad parallax has on their website, they have the software needed to use it in the propeller tool library.
    Good luck - Please do not use this thread to work your idea out. It will get lost and ignored then.
  • Keith YoungKeith Young Posts: 569
    edited 2011-08-26 20:23
    Is it possible to allow for real time Excel data filing?
    edited 2011-08-26 22:08
    Hey this is awesome!
    This might make a good addon to my black box sequencer so I can sample wav files into the sound output.
    http://forums.parallax.com/showthread.php?115258-TheBlackBox-Release-v2.0-Propeller-HSS-FX-Sequencer-with-Digital-Audio-SPDIF
    I'll probably just add on a 5th prop that is dedicated to wav file playback, and have it run a few channels of wave output.
    Thanks for this!
    CL
    edited 2011-08-27 04:56
    @roughwood - What? Its a WAV player driver.
    edited 2011-08-27 09:21
    I am still getting used to IE tabs... replied to the wrong thread. Sorry.
    edited 2011-08-30 05:00
    Could the noise problems people have with generating audio on the prop be eliminated by using dual cogs and or dual output pins tied to each other also?
    There has got to be a hardware way to eliminate this noise using multiple cogs and multiple output pins putting out the same signals? Differential like...
  • ErlendErlend Posts: 612
    edited 2011-08-30 05:36
    Reading that the sound is ok on speaker and headphones, but not on more sophisticated equipment gets me thinking that this could be RF interfering with the sound amplifiers and create (new) noise. The fix would be to fit chokes on all outgoing wires. An RC network would not be able to stop the RF.
    E
    edited 2011-08-30 05:48
    The driver has something to compenstate for that now. Please read trhough the source code and look at the "DACDitherEngineStart" and how it is used in the demo. Thanks,
    Using a 2 cog approach the sound quality is very good.
    @Erlend - Yes, the hardware you use also greatly affects audio quality like any other device. The amount of work put into the hardware design affects the quality of the sound. Propfessional audio deveices don't just use a RC circuit to make audio. Lots more goes into them. =)
