Make 2 thing in the same time ?
Hello,
I have a BS2 and I what to know if it's possible to make a LED flashing at the same time that a servo is running ?
My project is to make my boe-bot running forward and make a LED flash in continuos at te same time. I what the LED never stop flashing even if the bot is running or stop. Is that possible to run tow different command at the same time?
Do you have an example for that ? I'm not sure haw to do this. Do I have to make another counter in the servo commande line ?
pulsout 1,850 'servo 1
pulsout 2,850 'servo 2
pause 20
next
toggle 3' LED on pin 3
goto a
