Robot over internet
Hi guys,
Im very new to robot and MC programming, but not new to application programming in Java and C++.
I want to build a robot with IP camera so I can control it over the internet with command to go forward, backward, left, right and etc while the Camera transmit the live images.
I want to ask if you guys think Im on the right track with my idea.
The Robot will use propeller MC with IP camera and RF module to receive signal from BS2 connected to a PC with a web server that receive the signal over the internet through maybe a USB port or serial port. The BS2 gets the command and send it to the robot through RF module. The user interface to control the robot is Java applet which will communicate with the Tomcat application server.
Borna
Borna
Do you just want the Propeller to control the movement of the robot based on the data received from the BS?
I don't think there should be a problem in controlling a robot this way.
So as you mentioned, the Propeller is only responsible for movement of robot
Also is it better to use wireless RF to communicate btween BS2 and Propeller or bluetooth device?
Borna
BTW, it's interesting that that all of the WowWee TrueTrack beacons (using Evolution Robotics' Northstar syatem) have disappeared. They used to be available everywhere, but now out of stock everywhere except for the Cozy Pineapple, a known ripoff joint.
I know this is possible, but is there better way of doing this among the robot builders?
It should be possible to put a web-cam on the robot and transfer the picture over the router.
You actually gave me another cool idea, transfer the picture to the laptop and implement vision recognition...
The Spinneret can execute code like any web server.
http: // myspinneret.com/servo.htm?id=1&position=500&ramp=7
The Spinneret parses the request and executes the appropriate logic block. There are many examples and source code on the Spinneret forum.
Check out Wi-Fi SPYKEE, manufactured in France for Erector. I have one and it's pretty nice. The source code is available, and there are a couple apps already made for Adroid (java based). And there is a dev site for it that has a 3rd party firmware...I think the major modification is it allows the camera to be on while it's charging.
The main drawback I have seen is the battery life and charging system. Many people use larger 9.6V packs for extended hrs, but I tried that and it did not work for me. Either it's just mine or the design has a buggy battery level/recharge system. Mine always shows it needs recharge, but I have gone through 3 batteries and even returned it to the company with no improvement after they returned it.
But it is completely usable as a remote net based camera, and quite a few people have modified it. The hardware with source code is well worth the price. It has other functions that can be adapted as needed such as LED control, mp3 player, basic security functions.
it's erco's deal of the day!
BTW, both bots have been Wooted for $99... seems like all robots end up on clearance, sadly and happily.
