Looking for a good calculator. TI / Casio? What's your favorite?
Hello All,
As I am going through Chapter 7 in the PE Kit again. Trying to understand counters better. I've been using the Scientific/Programming Calculator in the computer. I really need a stand alone version I think it would make life a little easier. Been looking around and at $100 + its a small investment. If I am going to spend $100 + I might as well get the best suited for electronics/programing.
I know there are a lot of Electronic Engineers and others here who might know what some of the better ones are, so i'll ask what do you use? Whats your favorite? And maybe why?
-Ron
-Ron
My HP was one of those hinged models (it was probably about '84 when I purchased it). I've heard the hinge caused a lot of trouble but I really liked having so many keys without having to use multiple "function shift" keys.
I'd also like to get a nice calculator again. I'm curious what others hear think about the ones they've used.
Duane
this is a the hands down Best I have ever used . the play back is SO usfull as you can reuse a eqation .
TI is WAY over rated .
and DAL is ideal for geeks .
Peter ..
Anyway an RPN calculator requires a little bit to get used to, but is is a great way to perform calculations.
I have a very good RPN on my android, too, but the keyboard of the HP is simply awesome.
Massimo
To this day, it take me a sec to get going with a non RPN calculator.
The plastic around the battery cover on mine broke which according to the article was common.
@Peter, The Sharp calculator is nice and cheap by I don't think it is in the same class as the HPs.
The HP-28s could differentiate (and integrate) polynomial equations. If I used the correct sequence in entering an equation, I could use Newton's method on an equation without stopping to store part of the equation to access later. I just needed to use "swap" a couple of times and all the information in the stack would fall nicely into their place in the larger equation. I'd then "Store Equation" and use the solver feature to use the output of the equation as the new input. I thought the calculator would give me an edge in my Chemical Engineering class but I soon realized just about everyone in the class had the same calculator and the teach wrote the tests assuming all the students had a 28s. Those were hard tests.
More confused than ever.
I think Peter's calculator of choice would fit the bill right now, but I am still interested in high end calculators. I guess in the end 2+2=3 no matter how much you pay for a calculator.
-Ron
I used an HP41CV back in the day, still have it but don't use it. Kinda neat, RPN isn't bad. Nobody ever asks to borrow your RPN calc, if that helps!
My HP 42S is 20 years old and still kicking... calculating.
In college I used an HP 41CV with extended functions module.
Jay
The HP stuff, umm, where can you even buy them anymore? Plus the company has a history of bad CEO's and engineering-hostile business practices.
I never understood the gang-up regarding younger people and their TI calculators. The "real engineers use" blahblahblah. That was old and stale back in 2000. Not trying to start a flame war, but if something gets repeated enough without question, it becomes "true".
So here's a case for TI calculators:
A TI-86 got me through high school. It had a convenient way of entering polar notation. The scientific notation could be switched to "engineering notation" so that instead of showing 2.2e-2 it would show 22e-3 which was really handy when working in units like milliVolts or microFarads. Unfortunately, TI killed this line. So I'm in the same boat as those with HP calc's.
Later in college with as far as checking my advanced math work, the TI-89 series was okay. Wasn't great because there can be such a thing as too many menus and modes and options. Unit conversion helped. Pretty print (or whatever it was called) helped with those nasty formulas when I was at the point of sheer math exhaustion.
I can remember the point when I realized that getting close to the right answer (in the ballpark) was enough for a lot of real world engineering and learned how to use a ruler and log tables.
More personal stuff: RPN is kind of bleh, I tried it a billion times. Never liked it. It was never a selling feature for me. The main reason being that expression evaluators in most computer programming languages use infix notation, and it was just frustrating bouncing between the two. I would rather make it "harder" on the calculator's cpu rather than "translate" as I bounced back and forth. It was a matter of expedience, not mental laziness.
DVORAK was arguably supposed to be a better keyboard layout, but sit down at any computer and what do you see? RPN was like that to me.
The TI-calculators allow you to assign sub-calculations to variables (A, B, C, F, etc) with that arrow symbol along with printing the result. Then for the final answer type A / B or something to get the final result.
Anybody have the TI Nspire?
Ron
Ron
My favorite calculator of all time is my HP 41cx. I don't use it that often because it can never be replaced if something happens to it.
I've had numerous HPs, TIs, Casios, and Sharps over the years. All of them have been pretty good calculators so I don't think you can really go wrong with any of them. Although I have a few, I don't really think it's worth paying a lot for a large screen graphing calculator unless you really have the need. I haven't found them that useful, but that may just be me.
I do definitely prefer RPN.
The collage I went to would only allow certain model TI's to be used during tests, thats why I got the TI85.
The TI89 has lots of apps and games;)
http://www.ticalc.org
-dan
It's also good for accounting, calculus (directly entered)... Pretty amazing stuff.
IMO, Casio is just ok, but I can't stand the TI's I dunno if it's the look, the feel, the function..... just can't stand em'
One feature I plan to add is a calculator. I've often wondered how many of the funtions of my old HP I could reproduce. Would the limiting factor be the Prop or my ability to program the Prop? I have a strong suspicion it's the latter.
Now I have an HP-50g and it is a bit over the top with features and software. The complete manual is something like 700 pages and only in a PDF file.
Frankly, now that each and every computer OS has a calculator included, it is a bit crazy to buy one.
The HP-35S that others mention as being available is likely their best. I believe that you can switch between RPN and Conventional calculator mode, but it is a shame not to learn and use RPN. My PDA and computers have an RPN emulator installed.
At times I miss my log-log slide rule.
I do appreciate all the feedback. I am aware of all the apps for Android I have a G2. And you can get most of the Android apps in the Chrome Web Store maybe all of them not sure, which is nice Angry Birds with your mouse.
Well thanks again I need to take some pics of my current project and post it in the Project Forum as an in progress project, hopefully by doing that it will help me stay focused and actually finish it, and of course to share.
-Ron
What I use now is 'Free42' which is an emulation (model should be obvious) running on my Nokia N900 phone. I looks exactly like the real thing, but I can switch it from 'portrait' to 'landscape' form as I wish. This serves my needs. I'll probably try to get my HP-16C running again at some point - there was a problem with the battery connection and the calculator ended up in a drawer.
-Tor
RonP, you said 2+2=3. For us RPNers, that is 2 enter 2 +. My HP keeps coming up with 4! ;-)
The TI-89 looks really good. Fell in your cart, huh?
Oh yeah, the RPN thing reminded me of something. If you guys would stop bringing stuff up that goes right over my head. I wouldn't spend so much time searching for what your talking about and maybe I could progress a little further with the Propeller.
Whit maybe it was a little tremor or someone bumped the shelf.
Ron
Why so? You can enter all the numbers once and review them as you go. Then you can run a total. In that way, you don't find yourself repeatedly entering and summing until you get answers that you are sure you are right.
The original 10-Keys had a paper tape and you would verify accuracy by checking the tape after the fact, but now many calculators don't offer any review.
So, you can either go RPN with concurrent verification or Conventional with after-the-fact verification.
In input keys on the TI or Casio are not anywhere as good as those on an HP for tactile feedback.
