Microcontroller help. In over my head.
Hi everyone. I'm glad to have found this forum. I saw the website on a microcontroller starter kit at Radio Shack. I'm hoping I can find some insight here, and I am willing to learn whatever I need to learn about electronics to make my project happen.
I need to build a microcontroller, whose only job is to take a short video clip, output it to an LCD screen, and loop it. I'm hoping to make it battery run. I have the soldering iron, I have the will to do it, I am just lost as to how I can go about making this.
Can anybody help?
Can anybody help?
I am assuming I would need to load some simple distro of linux with an application that would automatically cue up the video, and play it over and over again. Or is there a simpler way to program an SBC that wouldn't require an OS?
I apologize if my questions seem simple, but I am starting out from almost no basic knowledge here.
It sounds like you are trying to find the simplest and least expensive way to accomplish a specific task rather than taking on a project for your own enjoyment. If that is the case my approach would be to buy a complete computer (new or used) and load it with the operating system and software required (Linux or Windows). I wouldn't even consider an SBC without an operating system. By the time you add up everything needed the SBC approach is considerably more expensive unless you are planning on volume production.
Are you under any other constraints such as physical size, power availability, or harsh environment?
You could also buy an iPad Touch to handle the video using its composite video output cable. The resolution will be lower than 1280 x 720. You can write a program using NSBasic/App Studio that can play video looping it. Since this compiles into JavaScript, you could also do the same thing with an Android device.
As Kwinn said, it depends on whether your doing this for the journey or the outcome.
It would depend on whether you want to have the fun building/integrating/writing SW/ building a case/troubleshooting/etc. or whether you want to configure something pre-built.
This seems to be the best idea so far, with Kevin Woods suggestion of using a tablet/netbook/etc. a close second. Assuming that all you want to do is play a video in a continuous loop.
http://ics.nxp.com/support/microcontrollers/lcd/
