Need help with code for led controller.
Hi, i have experimented, and made some led experiments but i am in need of something that i can not manage to do. I have 4 LED pods, 2 red, and 2 blue, each made of 44 LED's which will be powered by 4 transistors. I need a program that will enable me to run threw multiple different flash/strobe/chase/wigwag patterns and adjust the speed using a pot. I have made some simple 2 pattern codes but i am at a loss. I would like as many patterns as possible, or in the area of 10-20. If someone could point me in the right direction, or if someone has the time to write a code for me i will gladly reimburse you via paypal, something we can discuss in PM. Btw the stamp is a basic stamp 2 homework board. thank you!
Andrew.
Andrew.
The Stamp can only do one thing at a time,But it can do it pretty fast.Way faster than our eyes can keep up.
Experiment #31 in the Stamp Works maunal shows and explains how multiplexing works.
http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
This is a good start for your project.
I patiently await your timely replie$.
So you would be willing to do this?
