Voltage Regulators
I really like my LM317 for the fact that is ADJUSTABLE via a pot but the only problem is that it gets too hot. Does any company make an ADJUSTABLE voltage regulator similar to the LM317 but with such a high efficiency that it needs a small heat sink or no heat sink at all?
http://www.national.com/en/power/simple_switcher/simple_switcher_lm258x.html
I have both of the regulators Mike linked to. I like them. I'm sure there are less expensive regulators that do the same thing but the Dimension Engineering regulators don't require additional component or custom circuit board. They're also very efficient.
Duane
