New Propeller IDE V1.3 — Parallax Forums
PublisonPublison Posts: 12,366
edited 2011-06-24 16:31 in Propeller 1
Seems to run OK. Have not banged it a whole lot. Available here:
http://www.parallax.com/PropellerDownloads/tabid/832/Default.aspx
Other new stuff including the new LION Charging Board:
SALE! and New at Parallax - Propeller Tools, Li-ion Charger
Update to original post - SALE! Propeller Starter Kit (#32300) now $79.99 for a limited time!
New releases for the Propeller/Spin Tool Software (v1.3), the Parallax Serial Terminal (v1.2.4), the Propeller P8X32A Datasheet, and associated errata - all available here
"We've also released a new product - Li-ion Power Pack /Charger - 2 Cell (#28986) and a High-Capacity Li-ion Cell (#28987) which works with the charger. A really sweet new product that works with so many projects and it is Made in the USA, here at Parallax by our fantastic manufacturing team.
http://www.parallax.com/Store/Robots/AllRobots/tabid/755/ProductID/758/List/0/Default.aspx?SortField=ProductName,ProductName
http://www.parallax.com/Store/Components/Hardware/tabid/156/ProductID/759/List/0/Default.aspx?SortField=ProductName,ProductName
    edited 2011-06-23 14:49
    Publison wrote: »
    EDIT: Sorry Mr Bumb. Did'n' see your previous post.
  • LeonLeon Posts: 7,620
    edited 2011-06-23 14:50
    You don't need to download the new terminal program and data sheet, they are included in the Propeller Tool download.
    edited 2011-06-23 16:46
    Leon,
    I believe the PST Terminal program, Data Sheet, and Manual all have a new revision number as of today.
  • Don MDon M Posts: 1,654
    edited 2011-06-23 17:27
    What changes or upgrades were made? Anyone know?
  • Mike GMike G Posts: 2,702
    edited 2011-06-23 18:02
    I was hoping you could copy (ctrl-c) from the Parallax Serial Terminal. Is there any way to do a copy to the clipboard in the PST?
    edited 2011-06-23 18:07
    Mike G wrote: »
    Select the stuff you want (becomes inverted). Then press (and hold) ctrl+c until the selection is reset.
    Update: The hold bit is a red herring. It's just in the past I had to press ctrl+c rather longer than I normally do so I remembered that bit wrongly. Anyway, I re-verified and right now it's simply press/release.
  • Jack BuffingtonJack Buffington Posts: 115
    edited 2011-06-23 20:56
    I would really LOVE to see the printing issues be addressed. The end of every page is clipped off and I really dislike wasting toner (and the fact that it makes things less readable) to shade the background behind the text. Turning off color printing seems to just make the areas around the text white but the shaded areas are still everywhere else.
  • Alexis64Alexis64 Posts: 42
    edited 2011-06-23 23:43
    Thank you - great fix...
    I see that the "Save As..." bug still in there...
    Start the program, load an object (any), press F8 and save the binary. Close the F8 window.
    Go to File, Save As and you'll notice that the File Type selector is now defaulting to .binary and not .spin
    If you type a file name (and do not add the .spin) it will save your source with a .binary extension and give you a nice white background window ...
    Maybe in 1.31 ?
    edited 2011-06-24 09:02
    Re: Printing.
    Just copy, paste to notepad, then file print. That's a kludge, but it beats wasting print resources.
  • JoannaKJoannaK Posts: 44
    edited 2011-06-24 14:28
    Alexis64 wrote: »
    Maybe in 1.31 ?
    Bug with Nordic keyboards seems still open. With Fi/Sw keymap if one presses Alt-Gr + 4 to get $, the IDE inserts unnecessary Yen-sign before the Dollar ... ¥$
    (at least with XP sp2)
    edited 2011-06-24 14:55
    I still get an intermittant error when trying to copy (Ctrl C) text. Anyone else? Says it can't copy to clipboard. But even though it says that it still copies anyway. Strange.
    Re: Printing.
    I use Edit | Preferences | Appearance tab and change Scheme: from Spin to None.
    This makes the background white.
