New Propeller IDE V1.3
Publison
Seems to run OK. Have not banged it a whole lot. Available here:
http://www.parallax.com/PropellerDownloads/tabid/832/Default.aspx
Other new stuff including the new LION Charging Board:
SALE! and New at Parallax - Propeller Tools, Li-ion Charger
Update to original post - SALE! Propeller Starter Kit (#32300) now $79.99 for a limited time!
New releases for the Propeller/Spin Tool Software (v1.3), the Parallax Serial Terminal (v1.2.4), the Propeller P8X32A Datasheet, and associated errata - all available here
"We've also released a new product - Li-ion Power Pack /Charger - 2 Cell (#28986) and a High-Capacity Li-ion Cell (#28987) which works with the charger. A really sweet new product that works with so many projects and it is Made in the USA, here at Parallax by our fantastic manufacturing team.
http://www.parallax.com/Store/Robots/AllRobots/tabid/755/ProductID/758/List/0/Default.aspx?SortField=ProductName,ProductName
http://www.parallax.com/Store/Components/Hardware/tabid/156/ProductID/759/List/0/Default.aspx?SortField=ProductName,ProductName
EDIT: Sorry Mr Bumb. Did'n' see your previous post.
I believe the PST Terminal program, Data Sheet, and Manual all have a new revision number as of today.
http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerDownloads/PropellerToolSoftware/tabid/609/Default.aspx
Update: The hold bit is a red herring. It's just in the past I had to press ctrl+c rather longer than I normally do so I remembered that bit wrongly. Anyway, I re-verified and right now it's simply press/release.
I see that the "Save As..." bug still in there...
Start the program, load an object (any), press F8 and save the binary. Close the F8 window.
Go to File, Save As and you'll notice that the File Type selector is now defaulting to .binary and not .spin
If you type a file name (and do not add the .spin) it will save your source with a .binary extension and give you a nice white background window ...
Maybe in 1.31 ?
Just copy, paste to notepad, then file print. That's a kludge, but it beats wasting print resources.
Bug with Nordic keyboards seems still open. With Fi/Sw keymap if one presses Alt-Gr + 4 to get $, the IDE inserts unnecessary Yen-sign before the Dollar ... ¥$
(at least with XP sp2)
I use Edit | Preferences | Appearance tab and change Scheme: from Spin to None.
This makes the background white.
