How are you powering your Spinneret?
I'm simply curious how folks are powering their Spinnerets.
Since my Spinneret is near my computer, I'm using 5v/Gnd from the computer's 3.5 connector to power the unit using the three pin connector.
OBC
OBC
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/motherboard/List/0/SortField/4/ProductID/470/Default.aspx
The power connections do not work directly with the Spinneret unless you modify the jumpers on the daughterboard. I was going to do that and then I got lazy.
The power on the daughterboard is supplied to the 3-pin headers (e.g., for servos). I run a short jumper cable (with only two conductors, +V and GND) from one of those headers to the auxiliary serial header on the Spinneret (J6, next to the RJ45 jack).
Edit:
I knew this had been discussed before. There are more details on using the daughterboard here:
http://forums.parallax.com/showthread.php?127160-Powering-up-your-Spinneret-without-releasing-the-magic-smoke.&p=954301#post954301
In multi-prop testbed: from Pro Development board Vin
It's not POE power over ethernet. It's power near to ethernet. I think that PNE or PNtEwould be a better name than Power over other Pairs for this project.
I will be using a Parallax serial LCD that uses 5VDC 50ma with light on or 10ma light off and a Sensirion Temperature/Humidity Sensor 2.4 to 5.5 VDC 30 μW so I decided to power it with 5vdc on pins 2 and 3 of J6. As I understand it in this configuration 5v will be the signal level on J6 pin 1.
Basically I plugged a DC wall wart into unused pairs in some CAT5 on one end and on the other terminated in a low profile box with a 5v regulator and filtering.
I used the schematic for the Spinneret to select the filter caps. I'm doing 5v where the Spinneret schematic section is doing 3.3vdc. I'll appricate any comments on values.
After reading a few entries in this thread I've decided that if I add the proposed addition I'll put the 3.3v regulator in series with the output of the 5v regulator rather than in the configuration shown.
Questions:
- Are the 10uf caps acceptable for the 5v regulator filtering?
In this configuration supplying 5vdc regulated to pin 2 of J6- Can I run the serial LCD from pin 1 of J6?
- Will the signal level be 5vdc on J1 pins 7 - 10?
Thanks.
