parallax development board rs232
hi, i've lost my usb connection and trying right now to connect the board with a rs 232 cable to a com port on my pc.
i do get an echo on com1 but the software says: No basic stamps found.
my questions are:
1 can i connect my develpment board with a rs232 cable to my pc to program the stamp module?
2 what are the correct com port settings?
thanks in advance
my questions are:
thanks in advance
my questions are:
thanks in advance
i have the professional development board with the bs2sx rev f chip(and others bs1 40 pinchip etc).
is it possible to program the chip with a rs232 cable?
thanks in advance
can i use bigger ones?
Angel2indigo, if this is the board you have you should be able to use the DB 15 connector just to the right of the USB connector in the photo.
Is there a number in the lower left hand corner? 28138?
It seems they used the same number for USB and Non-USB board. Can't find the schematic for the USB board.
Are you sure that's a DB-15 and not a DB-9?
edit: I dug out my Parallax binder and found the original documentation. I scanned the page with the USB circuit and made it into a pdf. It's the first time I ever used OpenOffice to export a pdf, so if you have problems with the pdf let me know and I'll try something else. I think the file size is way too big, but it's the best I could do at the moment.
edit2: I checked and the USB connection was present on the board in the 2007 catalog, but gone in 2008.
