Coming Soon - A New GPS Receiver Module!
Hey everyone!
We're still placing the finishing touches on the documentation, but I figured I'd drop in and give you a little sneak preview of this exciting new sensor.
This features a VPN1513 GPS Receiver & a Propeller co-processor. The each IO pin of the Propeller is also broken out, so the module is fully reprogrammable and can easily be used as a standalone device! Some features include:
Communication with the VPN1513 GPS Receiver Module is done through an asynchronous serial interface at 9600 baud. With a quick baud rate update, this module is compatible with the BASIC Stamp demo code for the Parallax GPS Receiver Module.
A schematic for the sensor is attached, let us know if you have any other questions or feedback!
Cheers,
Jessica
- Fast satellite acquisition time
- Fully Open Source
- High tracking sensitivity (-159 dBm)
- Onboard LED for satellite acquisition feedback
- External antenna included
- Track up to 20 satellites
- Battery-Backed SRAM
Cheers,
Jessica
the big question, what will it cost?
Thanks...
Larry
@lfreeze - Hopefully it will be up for sale today or tomorrow. Yes, it's WAAS enabled, and I'm not sure on the cost yet. Will let you know!
Cheers,
Jessica
Last question: what's the connector type and cable length used for the antenna?
Cable length: ~9 ft
Connector: MCX
One suggestion: I know the module schematic is available as a .sch file in the Open Source Downloads section. But it would also be nice to include it in the documentation PDF.
I sent an urgent ticket to find out the dimensions as I need to add them to a pcb that I am hoping to send off tomorrow. Can you or anyone else help?
In case anyone else is wondering, the files are in Eagle. :]
Cheers (from 'across the pond'),
Jessica
Eric
You can find the firmware for the onboard Propeller on the GPS Receiver's product page under the 'Open Source Downloads' heading at the bottom of the page.
The code in it's current state is for the Propeller to be used as a co-processor. But it should help you develop your own code to make the Propeller a standalone device.
Hope this helps!
Cheers,
Jessica
I'll come by tommorrow, need to pickup that and the breadboard kit for the C3
Rick
