Destination indexing question — Parallax Forums
User NameUser Name Posts: 1,451
edited 2011-06-02 22:37 in Propeller 1
When using self-modifying code to store an array of longs, is this the customary way to increment ddddddddd?
label	mov	0-0, data
	add	label, dest_inc
dest_inc	long	%10_0000_0000
Or is there some super slick way that I don't know about? The manual seems rather mute on the entire topic.
    edited 2011-06-02 20:35
    No, you've got it right.
    edited 2011-06-02 20:43
    There is a gotcha, that if you self modify immediately before the label your modifying it won't work the way you might think... basically you need an additional instruction to separate the self-modification from the label being modified or else it won't propagate until the next iteration.
    edited 2011-06-02 20:46
    Thanks, Phil!
    Right. In this case my intent was to increment the destination in anticipation of the next use of the indexed move.
    You can also define
    dest_inc    long     1<<9
