Problem reading second byte from 16bit ADC "ADS1110"
I`m unable to read the second byte from the ADS1110, it returns only logic high`s (adc0[1] = 255)
Is there anyone with an idea?
PUB i2cRead | i, i2cWriteData
dira[adc1sda] ~~
dira[adc1scl] ~~
outa[adc1sda] := 1
outa[adc1scl] := 1
outa[adc1sda] := 0
outa[adc1scl] := 0
'write
i2cWriteData := $91 << 24
repeat 8
outa[adc1sda] := (i2cWriteData <-= 1) & 1
outa[adc1scl] := 1
outa[adc1scl] := 0
dira[adc1sda] ~
outa[adc1scl] := 1
outa[adc1scl] := 0
'read1
i2cData := 0
repeat 8
outa[adc1scl] := 1
i2cData := (i2cData << 1) | ina[adc1sda]
outa[adc1scl] := 0
dira[adc1sda] ~~
outa[adc1scl] := 1
outa[adc1sda] := 0
outa[adc1scl] := 0
dira[adc1sda] ~
adc0[0] := i2cData
'read2
i2cData := 0
repeat 8
outa[adc1scl] := 1
outa[adc1scl] := 0
dira[adc1sda] ~~
outa[adc1scl] := 1
outa[adc1sda] := 0
outa[adc1scl] := 0
adc0[1] := i2cData
outa[adc1scl] := 1
outa[adc1sda] := 1
You should anyway not drive the SDA pin High. For that I2C uses a pullup. To output a HIGH you set dira=0 and to output a LOW you set dira to 1 (and the outa bit stays always Low).
Here is a untested changed version of your Read methode:
CON OUTP = 1 HIGHZ = 0 LOWZ = 1 PUB i2cRead | i, i2cWriteData outa[adc1scl] := 1 outa[adc1sda] := 0 dira[adc1sda] := HIGHZ dira[adc1scl] := OUTP dira[adc1sda] := LOWZ 'start condition outa[adc1scl] := 0 'write i2cWriteData := $91 >< 8 repeat 8 dira[adc1sda] := i2cWriteData ^ 1 & 1 i2cWriteData >>= 1 outa[adc1scl] := 1 outa[adc1scl] := 0 dira[adc1sda] := HIGHZ 'ack from ADC outa[adc1scl] := 1 'read ACK here if necessary outa[adc1scl] := 0 'read1 i2cData := 0 repeat 8 outa[adc1scl] := 1 i2cData := (i2cData << 1) | ina[adc1sda] outa[adc1scl] := 0 dira[adc1sda] := LOWZ 'ACK outa[adc1scl] := 1 outa[adc1scl] := 0 dira[adc1sda] := HIGHZ adc0[0] := i2cData 'read2 i2cData := 0 repeat 8 outa[adc1scl] := 1 i2cData := (i2cData << 1) | ina[adc1sda] outa[adc1scl] := 0 dira[adc1sda] := LOWZ 'ACK outa[adc1scl] := 1 outa[adc1scl] := 0 adc0[1] := i2cData outa[adc1scl] := 1 'stop condition dira[adc1sda] := HIGHZThe SCL line is driven High and Low here so you need no pullup on SCL. But SDA needs one.Andy
The changes you made to the code works perfect.
