Problem reading second byte from 16bit ADC "ADS1110" — Parallax Forums
avionikerenavionikeren Posts: 64
edited 2011-06-02 13:42 in Propeller 1
I`m unable to read the second byte from the ADS1110, it returns only logic high`s (adc0[1] = 255)
Is there anyone with an idea?
PUB i2cRead |  i, i2cWriteData
   dira[adc1sda] ~~
   dira[adc1scl] ~~
   outa[adc1sda] := 1
   outa[adc1scl] := 1
   outa[adc1sda] := 0
   outa[adc1scl] := 0
   'write
   i2cWriteData := $91 << 24
   repeat 8
     outa[adc1sda] := (i2cWriteData <-= 1) & 1
     outa[adc1scl] := 1
     outa[adc1scl] := 0
   dira[adc1sda] ~
   outa[adc1scl] := 1
   outa[adc1scl] := 0
   'read1
    i2cData := 0
    repeat 8
      outa[adc1scl] := 1
      i2cData := (i2cData << 1) | ina[adc1sda]
      outa[adc1scl] := 0
    dira[adc1sda] ~~
    outa[adc1scl] := 1
    outa[adc1sda] := 0
    outa[adc1scl] := 0
    dira[adc1sda] ~
    adc0[0] := i2cData
    'read2
    i2cData := 0
    repeat 8
      outa[adc1scl] := 1
      outa[adc1scl] := 0
    dira[adc1sda] ~~
    outa[adc1scl] := 1
    outa[adc1sda] := 0
    outa[adc1scl] := 0
    adc0[1] := i2cData
    outa[adc1scl] := 1
    outa[adc1sda] := 1
  • avionikerenavionikeren Posts: 64
    edited 2011-06-02 09:37
    Please help me with this, I`m totally stuck...
  • AribaAriba Posts: 2,695
    edited 2011-06-02 11:14
    I think the problem is how you drive the ACKs after a Read. OUTA[SDA] is high when you set the clock high and then you drive it to Low while SCL is High -> that is a new start condition.
    You should anyway not drive the SDA pin High. For that I2C uses a pullup. To output a HIGH you set dira=0 and to output a LOW you set dira to 1 (and the outa bit stays always Low).
    Here is a untested changed version of your Read methode:
    CON
       OUTP  = 1
       HIGHZ = 0
       LOWZ  = 1
       outa[adc1scl] := 1
       outa[adc1sda] := 0
       dira[adc1sda] := HIGHZ
       dira[adc1scl] := OUTP
       dira[adc1sda] := LOWZ    'start condition
       outa[adc1scl] := 0
       'write
       i2cWriteData := $91 >< 8
       repeat 8
         dira[adc1sda] := i2cWriteData ^ 1 & 1
         i2cWriteData >>= 1
         outa[adc1scl] := 1
         outa[adc1scl] := 0
       dira[adc1sda] := HIGHZ   'ack from ADC
       outa[adc1scl] := 1
       'read ACK here if necessary
       outa[adc1scl] := 0
       'read1
        i2cData := 0
        repeat 8
          outa[adc1scl] := 1
          outa[adc1scl] := 0
        dira[adc1sda] := LOWZ    'ACK
        outa[adc1scl] := 1
        outa[adc1scl] := 0
        adc0[0] := i2cData
        'read2
        i2cData := 0
        repeat 8
          outa[adc1scl] := 1
          outa[adc1scl] := 0
        outa[adc1scl] := 1
        outa[adc1scl] := 0
        adc0[1] := i2cData
        outa[adc1scl] := 1       'stop condition
    The SCL line is driven High and Low here so you need no pullup on SCL. But SDA needs one.
    Andy
    Thank you very much!!
    The changes you made to the code works perfect.
