Waterproof ultrasonic sensor
Hi!
I have heard that Parallax soon will come out with a ultrasonic sensor witch can be used in heavy envirements and almost waterproof..
Is this true? if so,when does this come in the store?
regards
Robert
regards
Robert
There is a sensor similar to the one you are referring to; however it is still in the R&D phases so a release date has not been determined.
Thank you for your patience,
Respectfully,
Joshua Donelson
www.parallax.com
Post Edited (Joshua Donelson (Parallax)) : 10/28/2009 7:53:34 PM GMT
http://www.maxbotix.com/BUY_NOW.html#LVMaxSonarWR1
http://www.maxbotix.com/uploads/LV-MaxSonar-WR1-Datasheet.pdf
Yes, we have one in the final stages of qualification right now. Please see below. The finished product will not utilize the 3-pin header - it will have a wiring harness integrated to the design. The conformal coating will make it more resistant to humidity and wet environments. The following graphic is taken from a distributor webinar we conducted in April. We have slid from the August delivery date, but we're trying today to make up for loss time.
I've been using shrink wrap for a couple of years now or maybe longer to keep the water out of My non water tolerant Ping. The shrink wrap does'nt last long either. I was just about to build a contraption with a shutter and rain detector and a bunch of code mods to the BS2 just to handle the lite water splash from rain.
This sounds like just the thing for My gate opener and any other out door projects.
I can also see some nice Industrial applications too.
_____count me in _______$WMc%_______
The Truth is out there············································ BoogerWoods, FL. USA
Within ten days I'll know a bunch more about this sensor. We decided to do another proto.
Thanks, Ken Gracey
mike
Of all the things I have lost...
I miss my mind the most.
any update on the ping h20 weatherproof sensor?
thanks pete
We've experienced some late design troubles on the product which will delay the release for a significant time. At this point we have no release date in sight.
Parallax Inc.
So, how are things looking for 2011?
Vern
Ken do you have news for us about waterproof sensors?
thanks
regards
Simon
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/ProductID/755/List/0/Default.aspx?SortField=ProductName,ProductName
Can you tell us if you remove transducers off the ping sensor and change them with these
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/ProductID/755/List/0/Default.aspx?SortField=ProductName,ProductName will the ping sensor work agian
Thanks any and all info you have in this matter
there are many crickets in the forum very depressing.IMO parallax would sell more parts with more help in the forums.
completed projects leave empty hands--->for more parts
