Testing out my first StingRay - Voltage is key for motors
I built the StingRay last week, however ran out of time to play with it. Finally had a couple minutes yesterday to plug it in.
I downloaded the Left Motor, Right motor tests with it hooked up to my bench power supply on the barrel connector. Power status Lights were green and ready to go, however no action. I have been powering my prior Prop boards with 6volts on the bench top supply, no issues, so I didn't think much about that. Unfortunately I couldn't troubleshoot much until today. I knew that given the quality of Parallax, it had to be a user (me) issue.
I downloaded the Robot controller board manual and did some more digging. I was about to start checking pins when I figured I should at least give it as much voltage as the battery pack would (6 AA) at ~9 volts. As soon as I got up to about 6.5 volts, the motors came to life...
I haven't worked with a board that had a power status light on it. Perhaps future revs should set the min threshold higher? Though it would of course depend on how much other stuff is running off of Vin. I had 3 pings on there too.
I learned my lesson on this one, double check the voltage specs considering the number of components.
I finally put the batteries in, downloaded the String Ping Demo and had a good time watching it dance around the hall way!
Thanks for another great product Parallax!!
7.2v is fine - that's 6 1.2v rechargeable AAs. I've been testing/running with 7.2v RC battery packs (6 sub-c NiMH cells, 3800 mAh (on the label, not tested)).
Been searching for some camera options also on Amazon. Found a few cheap ones with a Tx/Matched Rx. Bad reviews though so have not tried them yet. On the forum, found most people going with WiFi based cameras. Keep me posted on what you end up with...
ms
ms
AA's are 1.5v, double checked since I was thinking about it.
Also here is the forum post about the new battery option: http://forums.parallax.com/showthread.php?129011-New-Power-Solution-for-the-Stingray-and-more...
ms
Alkaline AAs are nominally 1.5v. NiMH and NiCd are 1.2v.
