servos - analog or digital
I have a project that needs a dozen or more individual motions, and I'm trying to keep it inexpensive, so I started looking around for any and all cheap motion devices - steppers, servos, muscle wire, relays, pneumatics, solenoids, whatever will do the job.
I've got some stepper experience, but only have a few steppers in the junkbox, and even with salvaged steppers, buying lots of controller chips quickly gets expensive. So I'm looking more at servos.
I'm a total servo beginner. I have an old Vex robotics servo, have played around with a couple of OBEX servo programs and have gotten it to work, but that's about the extent of my experience.
I went to the website for Hobbytown (a local hobby store) and see that they offer both analog and digital servos. They show a small analog servo at $9, which is about as cheap as I've seen around.
Is anyone here familiar with the analog/digital distinction in servomotors? Even the Parallax store doesn't say anything about analog/digital in its's servo offerings.
Which sort do the OBEX servo programs operate? Or can they operate either?
Does anyone know about this stuff?
thanks.
thanks.
http://www.hobbypartz.com/topromisesg9.html
Analog servos are not so accurate and don't do "extra" functions as digital servos might (position reporting, software reversable. etc).
The servo thing is all about the control protocol. Every 20ms , you send the servo a pulse of 1.5ms +/- 1ms (aprox). 1.5 ms pulse commands the device to the "center" position, increasing the pulse duration commands it to positions in one direction, less than 1.5 ms commnds it to positions in the other direction. Each servo is different, but the range is usually less than 180 degrees, and at some point "hits the stops" until you modify it or "bash through the stops"
If also read it's not a good idea to use a digital servo as continuous rotation servo (I read this somewhere in a Parallax tutorial, website or book).
I know at least some of the digital servos can receive refresh pulses more frequently than 50Hz.
Those servo controllers do look pretty handy, especially for the sockets, since making so many physical connections can get so awkward for those of us that are somewhat mechanically challenged.
It sounds like digital servos will behave like analog servos when receiving a standard servo drive signal, but give you the option of increasing the pulse rep rate for a bit faster control.
http://cgi.ebay.com/10X-Micro-9g-Servo-RC-Futaba-helicopter-Trex-450-SG90-/320669312759?pt=Radio_Control_Parts_Accessories&hash=item4aa96166f7
I have bought several, and they work fine for non-critical apps.
Depending on the digital servo, you also pick up some additional functionality (if you buy a programmer). I'm talking about servos that are controlled the same way analog servos are (and not things like the Dynamixels).
For instance, you can often set the max and min allowed angle, max speed, etc. These are typically done before using the servo in your application and not changed from within the device/robot/etc at run time.
Digital servos often have higher maximum torques and more precision (but they don't have to).
I have used digital servos in applications where I wanted to set the angle range to prevent damage and not rely on the code running on the device controlling the servos. I have also used them when I needed more torque. They can be a lot more expensive so I usually just use analog.
The digital servos I've used are all from Hitec and the programmer is relatively cheap ($20-$30). The last time I looked the programmers for other servos could get pretty expensive.
I'm pretty sure each brand of servo has it's own programing protocol and you can't interchange programmers, right?
Does your Hitec programmer connect to the computer?
I suppose it should be possible to listen in on the signal line as a servo is programed and figure out the protocol. That way your robot could change the servos programing on the fly. I think this would be more work than it is worth though.
Thanks for the extra information.
A couple of people mentioned this site, with lots of information -
http://www.societyofrobots.com/actuators_servos.shtml#digitalanalogservos
I don't mind $30 that much as compared to $23; they're both so much better than buying 10 of a $14 motor!
I believe this is the programmer I've got:
http://www.hitecrcd.com/products/digital/digital-servo-programmers/hpp-21.html
It connects to a PC by USB. A simple program on the PC is used to setup the servo.
