3D Designer for hire: Logos, product simulations, avatars, animations, etc. — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2011-06-07 05:33 in General Discussion
Hi,
I am now offering a service that I have seen asked for multiple times on this forum: 3D design work. Recently I have become better at this and have designed my cool avatar for this forum in this way. I am offering a SIMPLE 3D design service capable of producing things like this logo: http://microcontrolled.com/MicrocontrolledBanner.png
And simple Product Simulation Animations. (I have no current examples)
The problem is I don't know what to charge for this service. Professionals cost hundreds of dollars, but I'll charge a little less. Here is my pricing:
Still Image Design (Logos, Avatars, etc.) - $20 - $60
Animation Design (Product Simulation, Video logo intros, etc.) - $40 - $150
IF YOU THINK THESE PRICES ARE NOT JUSTIFIED, let me know about it and I will negotiate. Here is a simple chart of what makes things more expensive.
What makes it more expensive
- Design time is key. The more complicated the design, the more it will cost
- Render time is how long it takes the computer to generate the finished image. This is a key price effector in animations. For still images I use a very high-quality external render engine (rather then the built in one) called LuxRender. This cycles the CPU and makes the image more refined and realistic, meaning the longer it works, the better the image. This is no concern for me because I can pause the process at any time if I need to use my computer. HOWEVER, animations use the internal rendering engine, which consumes the entire PC. The longer the animation, the longer the render time, and the larger the cost. A 30 second long animation could take over 2 days or as little as a few minutes to render depending on certain parameters of the 3D design.
- Characters add a large amount of cost to any still or animation design. Animations will especially be effected by this because a full armature and rigging must be applied, which is a long and tedious process. The only exception to this is RoboMan, a character I designed a while back who is free to add to any animation or still image.
- Curves are tricky to make in a 3D landscape, so an excess of them will result in a higher cost.
- Clay Renders are images void of color. Requesting a clay render will greatly lessen the cost of any animation.
If you are interested in this service, or would like to request a quote, please contact me: info@microcontrolled.com
If you have any comments, questions, or sample requests please leave them below.
Microcontrolled
    edited 2011-05-30 18:50
    Micro,
    I think your prices are very reasonable -- if not downright cheap. But you do what you have to do to get your foot in the door. :) Good luck with your new venture!
  • RossHRossH Posts: 5,683
    edited 2011-05-30 20:57
    Hi Microcontrolled,
    I've been trying to come up with a new Catalina logo. I'd happily pay you to design a 3D one. I like the clean simplicity of my current logo (it's based on the classic "C Language" logo found in various places - e.g. here). But I'd really like to incorporate an image of an actual Catalina aircraft somehow. I like the Catalina because it looks like one of the slowest and most ungainly contraptions ever designed (e.g. see here) - but in fact it's perfectly suited to its job :smile:.
    I just can't seem to come up with a good idea for marrying the two together!
    If you're interested, send me a PM.
    Ross.
    edited 2011-05-30 21:00
    The Chinese are rather ruthless at 'killing the price' in negotiations. You have to charge enough to survive and not listen to shoppers that are not really willing to allow you to make a living.
    Ironically in Chinese, the phrase for knocking down a price sounds exactly the same as "kill the family".
    edited 2011-05-30 21:46
    RossH,
    Are you sure? I once saw a documentary about some guys flying a Catalina out of Egypt or some place. The thing could hardly get into the air:)
    Mind you I've always liked the lines of the Catalina.
    edited 2011-05-30 22:19
    Heater. wrote: »
    RossH,
    That's the point - the Catalina was used for missions where it's ability to fly very low (basically, skimming the water) and very slow (I think it's one of the slowest aircraft still flying) were positive advantages!
    The "blackcats" (black livery) were used for nightime raids against shipping, and I think the "whitecats" (white livery) were used for rescuing survivors of sunk ships and also downed airmen.
    BTW - that's why Bob Anderson's debugger is called 'blackcat'. He finished his first - but I then decided to call mine 'blackbox' because it sounded more 'aeronautical' than 'whitecat'.
    Ross.
    edited 2011-05-30 22:23
    Hey all, having hired Microcontrolled for a project in the past I'm pleased to provide a positive reference for his new venture.
    edited 2011-05-30 22:31
    RossH,
    That's the point - the Catalina was used for missions where it's ability to fly very low (basically, skimming the water) and very slow (I think it's one of the slowest aircraft ever made) were positive advantages!
    Haaah...I get it now, an aircraft designed to not fly and do it slowly. Perhaps the Zog and Catalina projects should swap names:)
    edited 2011-05-31 08:03
    @RossH: I've sent you a PM. I have already started working on it, and I have a model ready. I'll give you some sample renders via PM or email, and post them here with your permission.
    I never knew there was meaning to the name - very clever!
    @Ken: Thanks!!
    edited 2011-05-31 08:19
    Micro,
    Just ot of curiosity, which modeling and rendering tools do you use?
    edited 2011-05-31 09:30
    RossH wrote: »
    I'd really like to incorporate an image of an actual Catalina aircraft somehow. I like the Catalina because it looks like one of the slowest and most ungainly contraptions ever designed - but in fact it's perfectly suited to its job
    I was inside one of these old planes once.
    I went on a trip to Florida with my Grandparents in their motor home.
    We stopped in Alabama to tour an old navy battleship and there were
    some planes on display next to the ship. My grandpa got someone to let
    us on the biggest one, I'm pretty certain it was a Catalina, it's pretty big
    inside...but also very ugly in there :-)
    edited 2011-05-31 09:41
    @Phil Pilgrim: I model everything in Blender, an open source 3D development system, and render all still images with LuxRender. I export the scenes to LuxRender using the LuxBlend plugin. For animations I use the Blender internal rendering engine, which isn't bad, just not a nice as LuxRender but a lot faster rendering time.
    edited 2011-05-31 12:15
    @RossH: Is this a good Catalina aircraft? http://microcontrolled.com/CatalinaTestRender1.png
    edited 2011-05-31 12:26
    Hey!
    That looks really good micro :-)
    edited 2011-05-31 13:00
    @Holly: Thanks! If I had given it a few hours to render instead of a few minutes, it wouldn't look grainy, but this is just a test render.
    edited 2011-05-31 14:21
    Hi microcontrolled,
    That's very cool. Amazing that you can do it so quickly! The main problem I have with the Catalina is that it never looks very good (or even recognizable) in a small logo. As I said in my PM, if we end up not being able to include it then so be it.
    Ross.
    edited 2011-05-31 15:06
    Ross,
    It's sure to be more recognizable than this
    or this
    edited 2011-05-31 15:07
    I always think of Catalina Island when I see the Catalina C threads.
    Catalina has a spooky runway to land on.
    I wonder if the Catalina plane was named after the island?
    edited 2011-05-31 15:33
    Hi Holly,
    Yes, apparently it was - http://www.uswarplanes.net/aircraftnames.html
    Ross.
    edited 2011-05-31 15:35
    @RossH: As said in the PM, I don't care if we don't use it, I'll find some other use of it anyway. :-)
    @Phil: I always think of salad whenever I see the threads on Catalina. :-) I wonder why the bottle says it twice?.....
    edited 2011-05-31 15:36
    Ross,
    It's sure to be more recognizable than this ...
    I've named my software after a Salad Dressing??? Aaarrgghh!!!
    Ross.
    edited 2011-05-31 15:59
    The label is bilingual. The second one is in Spanish. :)
    edited 2011-05-31 16:12
    @Phil: Really! LOL!
    @RossH: I like your analogy with the aircraft better, I always thought you named it that because your software made something usually bitter delicious to use..... (Joke! I like SPIN way better than C)
    edited 2011-05-31 16:37
    Had some spare time and put this together real quick. Nothing to be used, just an idea.... http://microcontrolled.com/CatalinaLogo3.png
    It's grainy because I didn't wait for it to refine.....
    edited 2011-05-31 16:41
    Well, waddya know! I never realized I could speak Spanish!
    Hasta la vista, baby!
    edited 2011-06-06 13:11
    UPDATE: I've just finished the Catalina job, and you can see it in the next release of Catalina. (I don't know if he wants it published publicly)
    I'm now available for another job should someone have one. I'm trying to get more "Electronics money" and you know I'm getting desperate when I'm offering 3D work rather than consulting or something.
    edited 2011-06-06 15:52
    I can wholeheartedly recommend Microcontrolled's work. I'm still finalizing the way I want the final Catalina logo to appear, but it will definitely be included in the next release of Catalina.
    Ross.
    edited 2011-06-06 22:46
    Pester, pester, pester...
    So, let's see it!
    @Micro: Nice 3D rendering. What software are you using?
    edited 2011-06-06 23:01
    @Micro - I think I have a job for you, but I need to know a bit more about your abilities.
    Are you using Drupal for your personal web site? And if you are using Drupal, do your services include Drupal-related work such as page creation and development of navigational structures?
    @Ken: No, I currently use WordPress on my personal site. I had never heard of Drupal before, although if I had, I'd probably be using it. It looks like nice software.
    @potatohead: I use Blender for the modeling and LuxRender for the rendering, both open-source and free. I've been honing my Blender skills slowly over the last year, while I was in-between real projects (electronics and microcontrollers). However I originally learned it for CAD.
    (psst! logo is here: http://microcontrolled.com/CatalinaLogo5modified.png )
    I'll take it down soon, though
