Say-It Module Odd Experience (Thank You Parallax) — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2011-06-07 16:46 in General Discussion
Late last November I bought a Say-It module and it worked great for a month, but then mysteriously failed when one component got really hot and then it only returned comm errors after that. Parallax sent me a replacement as I was within the warranty period. But I didn't try the new one until last night.
As soon as I plugged it into the app mod socket, I smelled frying circuits and the Say-it GUI couldn't communicate with it. When I pulled the module out of the app mod socket one component was hot enough to burn my finger:
Ouch to say the least. Next time when pulling a circuit that's starting to smell bad I'll grab it by the sides. Frankly I'm mystified. I don't know if the modules or prone to fail or I'm doing something really wrong.
I am sure I plugged it into the ground, 0, 2, 4,..., 5v row. I checked the app mod socket with my DMM and ground was at ground, 5V at 5V, and the pins weren't shorted to either. But when I plugged in the second one it failed right away. The BS2 seemed to work fine after each module failed, so I really don't think there was high voltage at the pins.
Here's a picture of the module:
The component which got hot is the top rectangular on the left which isn't quite square on its pads.
What is that component? Any ideas if I messed up or is that component shorted because it isn't on its pads right?
    edited 2011-05-19 01:46
    That's a capacitor and yes, it's position on the pads could easily cause it to short to the resistor that is above it which would explain the "hot failure". I would recommend that you contact Parallax tech support as I would assume they will probably want to send it to the manufacture (by replacing yours)
    edited 2011-05-19 02:17
    I usually keep one finger on the voltage regulator when I power up something new - just in case I've done something wrong. It may be low tech, but it is a great indicator and preventer of damage at the initial assembly phase.
    It could be that the capacitor is rated for the wrong voltage or that there is a solder bridge some place. I am sure Parallax is more than willing to work with you on this as they really want customers to feel complete satisfaction with whatever they sell.
    If I am seeing correctly, that capacitor certainly does look as if it isn't fully on the pads as intended. Something may have been positioned wrong in the automated assembly process.
    edited 2011-05-19 06:06
    OK. Thanks to both of you. I've contacted them via e-mail.
    edited 2011-05-19 07:36
    If that was a tantalum capacitor then it could have been under rated or installed backwards. If the capacitor is installed backwards they will fail like that.
    I haven't heard of any other modules with problems like that so it is probably isolated to a few odd modules that got through QC...
    Thank you to Parallax for replacing the Say-It module. I was using the new one tonight and it is working fine for training. The next step is a voice controlled Penguin.
