Prop Board to Spin Studio
Is it Possible to link the Propeller Proto Board to the Spin Studio Board via the Prop Plug Connection's by reversing one side via a hacked sound cable from a cd rom drive.
Or has this already been tried and discussed.
Use your prop-plug as a reference for the pins.
TX ---- RX
RX ---- TX
GN ---- GN
(Skip the RES line)
You should be able to communicate with the FullDuplexSerial code using that configuration. Since I doubt you've started
to dabble much with Spin, load up PropDOS on both units, use the "terminal" command and you should be able
to type between the two boards. (Half-duplex should allow you see see what you are typing)
I'll play with this configuration later, but I see no reason why it shouldn't work.
Report back if you beat me to it.. [noparse]:)[/noparse]
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
