gps module & BS2 & high voltage smell?
Hi all,
I was fortunate enough for Santa to bring me·the·GPS module for Christmas.· When I plugged it in and went to test it with my bread board and bs2 using the documentation code and diagram, it was blinking red (as expected) but it started to give off a funny smell (you know the burning electronics smell).· I unplugged the 9volt from the BS2 board but I heard a pop before I could get it removed.
I later went and checked the voltage and it was giving a 4.93 as the voltage from my multimeter which is in the operating range for the voltage (Vdd to Vss)
Does anyone else get this smell or is it something wrong in what I did to hook it up?
-TLD
-TLD
- Stephen
The code I ran was the DOC code as well (see the .BS2 attachment)
Post Edited (theloneduck) : 12/29/2007 4:18:10 PM GMT
Sorry, but I don't have that book, but perhaps you could scan the page and U/L it.·
[noparse][[/noparse]Check your wiring, OM.]
The resistors are 220 Ohms
The GPS needs 115mA and that's more than the BS2's on-board regulator (the source of your "Vdd" /·5V)·can deliver.
I cannot say how the on-board regulator would fail in such an over-current event.· It's likely the source of the "pop" and the burny smell you've noted.· Better assess the situation without the GPS connected.· Does your BS2 still program, operate, etc. without the GPS connected?
Given your set-up, the·GPS needs its own 5V supply.
so the GPS module is trying to pull too much current from the stamp?· The code still runs fine when I run it without the GPS module (except the part about retreiving data from the module).
1) how much amperage does the BS2 push out via VDD
2) where does one find a 4.5 - 5.5 Volt battery?
As PJ Allen mentioned, you can put 3 alkaline cells in series, but the voltage is likely to stay in the 4.5 to 5.5 V range for only a short time. The battery's output voltage shifts with the load on them and decreases as they're drained of energy. You really need to have a voltage regulator and feed it with a higher voltage. Typically you use a "low drop-out" regulator that only requires an input voltage about 1/2V above the output voltage. For a 5V output, this is usually a 6V input supply, typically from 4 alkaline cells or 5 NiMH rechargable cells. You can also use an older / cheaper regulator ... the LM7805. This requires a 2V difference between input and output, so you'd run it from a 7.5 to 9V unregulated supply ... typically 5 alkaline cells or 6 NiMH cells.
Parallax's development boards' schematics are downloadable with their links on the webstore pages for the product. Download one of them (like the Board of Education) and see what they've done for their 5V regulated supply.
Post Edited (PJ Allen) : 12/30/2007 3:42:18 PM GMT
Connect it like Fig 7. Use 9 V connected to pin 1, the Input.
You can get it RadioShack:
http://www.radioshack.com/product/index.jsp?productId=2062599&cp=&sr=1&origkw=regulator&kw=regulator&parentPage=search
just a point of clarification for me... it I run a 9volt through the 78L05 to regulate the voltage to 5 Volts, do i need a resistor to pull the amperage down to 115mA?· And (according to some quick v/i=r calculations) it would be about 43 ohms correct?
Sorry for all the questions, like I said, Im rather new at this.
You really need to read the manual for the GPS module as to what voltage it expects. It sounds like it expected 5 volts, you supplied 9 volts, and the "pop" and smell was something being cooked to death. But maybe you're lucky and did no permanent damage.
Note, on the BS2 BOE board, they use a 7805 "TO220" package, which will regulate up to an amp of current at 5 volts output. I wouldn't use the regulator on the BS2 itself to drive ANY external circuitry myself.
The module and BS2 work fine now I have the last 7805 Radio shack had in stock.
If anyone is interested, attached is the debug window.
