Max voltage allowable on HB-25 servo input
Hi all,
I have read the HB-25 Motor Controller manual several times and have yet to see a max voltage spec for the servo input on the controller.
Does anyone know if an RC receiver being powered by 6vdc will damage the HB-25 if it is used the drive the HB-25 servo input?
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
TCIII
- Stephen
If you want to play it safe, you could put two diodes in series with the RC receiver output. That would drop 6V to less than 4.6V which should still be enough to drive the HB-25.
Thanks for the input. Much appreciated. You always give good advice.
I was hoping that someone from Parallax with knowledge of the HB-25 might have some input too.
TCIII
Never give up when things go wrong, Just work them out.
robosapienv2-4mem8.page.tl/
My Hitec R/C receiver came with a four AA cell battery holder and not the usual rechargeable 4.8 battery.
I got the receiver to work on 5 volts by powering it from my accompanying BOE while the BOE converted the servo output of the receiver and drove the two HB-25s on my rover.
TCIII
I had not seen one of those before, but it makes sense. Most servos are rated for 4.8V – 6V. 4AA alkaline batteries would give 6V, while 4 rechargeable AA cells would be 4.8V. Of course, most receivers will work in that range as well. Thanks for the info though. Take care.
