Piezo Film Vibra Tab Mass Sensor Problem
I'm trying to use a piezo Vibra Tab sensor. I've set up the circuit shown in the documentation and it works fine - with the sensor plugged directly into the circuit board. However, if I try to remote the sensor by more than about 12" of wire, I get a continual "triggered" indication. This sensor is totally useless if it can only be used directly on the board. Is it really so sensitive that the resistance of a foot of wire throws it off? My only idea is to remove the 220 ohm resistor from the circuit. Is there any reason I shouldn't do this?
Jeff T.
I don’t believe the sensor is the problem…It is the length of wire which is acting as an antennae. You may need to use some sort of front end on the sensor to be able to extend it out. Perhaps an op-amp of comparator and CAT-5 or other shielded cable will help you.
Learn something new every day, I suppose.
