What I've been working on- PropPLC
If you've noticed, lately I haven't been posting around the forums as much as I normally do. Main;y, this is because I've been busy with a new project: The PropPLC. Unfortunately, it was designed for a private company's use, and isn't for sale. I also can't post any schematics or much data about it. But I can share a little info about it with you, as well as a few pictures.
It's similar in design to the Basic Stamp PLC. It's features include:
-Propeller Multi-processor (in PropStick USB form)
-4 optically isolated digital inputs (active high)
-3 quadrature encoder inputs (data lines are pulled up to 3.3v for use with open collector output encoders)
-12 optically isolated digital outputs (12v active high, 500mA maximum current)
-USB Stick Data Logger
-RTCC
-FT232R USB with Mini-USB port (programming and PC coms)
-direct terminal block access to pins 28-31
-small foot print (4.5 inches square)
Let me know what you think
Craig
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
-RTCC
Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Nice work
Jeff T.
The "seimens" PLCs S7-300 and S7-400 series PLC you are have multi very fast micros inside and they are not just limited to Ladder logic they can be programmed in Statement logic, function block and ladder logic.. Now the other main line of PLCs are the AB Allen Bradley PLCs that can be programmed with all three ways like the siemens PLCs they also have the ablitity to be programmed in Visual Basic.. They also have muti communication protocols that are very robust and stand up to many harse conditions.
I do like the Prop and a PLC would be a good project but their are some many different applications a PLC has, it would take a long time to create all the interfaces in the industrial world the "Big Three" would pass you by...
One thing if you are interested in PLC their is a company called automationdirect.com they have some small modular PLC that are very nice units I have used them in many projects in the past..
Just wondering about dedicated analogue inputs .. any planned .. Also will the final version have good ground plane and Input and I/O filtering ? LC types for example .. Just saying this as I have quite a few Props in industry on dedicated P.C.B's and had a few minor issues with inductive loads and PSU transients .. What is the proposed application environment ?
JT
'Necessity is the mother of invention'
Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
How do you reference the arm ..?
When you trun the power off do you loose the present position ...??
we did something similar recently and used Renishaw abo(expletive)e encoders with SSI encoder interface.
protocol used is simple.. and lightning fast with the Propeller..
Ron mel oz
Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Great job on your PLC.
I have made a PLC with the BS2 and have been inproving on it every year for my holloween castle.
I never thought of using the propeller for that ?
Great job.
Will you be making pc boards for this for other to use ?
Rob7
Yep, but don't expect them to be released soon. It will be mid-summer at the earliest.
Thanks for your interest,
Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
