Using the PropPlug To Connect To BS2?
I am trying to use the usb propplug to connect/program a BS2 -- but for some reason the programmer doesn't seem to be able to connect. The pin connection that I'm using is:
Rx <--> Sout
Tx <--> Sin
RES <--> ATN
VSS <--> VSS
Also, it should be noted that I am using MacBS2 on an Intel MacBook w/ OSX 10.4 and the latest FTDI drivers. The propplug works fine with my propeller board with the same setup.
Any ideas?
Rx <--> Sout
Tx <--> Sin
RES <--> ATN
VSS <--> VSS
Any ideas?
bilboe: For the drivers google "FTDI OS X".
